Pscan and brake bleeding
can pscan operate the ABS modulator on an MG ZT for brake bleeding ..
ta
c
ta
c
by ceedy
Yes it can.
Please see https://pscan.uk/features/abs57.html
by pscan.uk
It certainly can and did a brilliant job on my pal's ZT last weekend, brought a lazy ABS pump back to life
by Notanumber
Can this be done for an MGF too, where on pascan can this be found.
Thanks
Thanks
by PipL
No, power bleed brakes is not supported for MG F.
by Roverlike
The following user(s) said Thank You: PipL
true, but my T4 does it (I had a go a few weeks ago on Rob Bell's MGF) so at least it is possible and I do have a reference tool that I can reverse engineer.
I'll add it to the list of things to do and Rob will be pleased when it's done.
by pscan.uk
The following user(s) said Thank You: David Aiketgate, Airportable
Have you been able to make progress with the ABS bleed function for versions 5.0 and 5.3?
by cbr888
Have you made any progress on this point?
by cbr888
I'm nearly there
by pscan.uk
The following user(s) said Thank You: Papaya
Time to create page: 0.443 seconds
