Software version 043C
Replied by pscan.uk on topic Software version 043C
Posted 9 months 3 days ago #219722
Hi, I bought a pscan back in 2015. It worked great, but I havent used it since 2016/17. I only installed it on one laptop, (running XP), which still works.
Do I just run the latest install? On the old laptop or a new laptop with Win10/11?
Thank you!
Either, or both.
pscan works on XP and on Window 10/11 so it's your choice.  Two laptops are supported so you can do both.  Personally I would say that an old worthless laptop is ideal for working on cars.  A workshop or drive where you fix your car is a rougher environment than a desk inside your house or office or whatever.
The following user(s) said Thank You: sworkscooper, Jaro
Replied by Cobber on topic Software version 043C
Posted 9 months 3 days ago #219725
I would just use the old laptop if that still works, but if it won't run on windows 11, you can create a virtual machine : install Oracle Virtualbox on you win 11 machine, and google for a virtuabox windows XP image. For accessing the USB port from the virtual machine, you need to configure that in your virtualbox settings. But AI is your friend, so won't be too hard.
Not recommended.  Virtualbox isn't supported and probably won't work.
Well there you have it......In this instance, AI clearly is not the friend it would like you think it to be! 🤣
The following user(s) said Thank You: sworkscooper, James
Posted 9 months 1 day ago #219777
AI clearly hasn't understood this webpage  https://pscan.uk/install/license.html
where it says
This software is designed to function only on operating systems that are directly installed onto your computers.
Virtualised operating systems are not supported.
the pscan software has to maintain some quite complicated protocols some of which are timing critical.  Putting a complete software operating system between the interface and the pscan software is going to add latency and other problems.
Replied by Jaro on topic Software version 043C
Posted 8 months 2 weeks ago #219991
Thanks everyone. Sorry for the delay in getting back to this thread. I downloaded the latest install and ran it on the old laptop (Win XP). It updated the firmware without a hitch.
by Jaro
Replied by Zeewulf on topic Software version 043C
Posted 3 months 1 week ago #222814
Any update on whether we can purchase the 30cm cable. My serial number is 00001341 so don't want to update as i then can't use my 1mtr cable.  Hence want to purchase new cable
by Zeewulf
Posted 3 months 1 week ago #222827
You can update to the latest software whether you have a 1.2 metre cable or the newer 30cm cable.  The new software works just fine with either cable.
The only reason to need a shorter cable is if you want to use pscan on a vehicle with CANbus and it doesn't work with the 1.2m cable.
If you don't have a CANbus vehicle then you don't need the 30cm cable.
If you have a CANbus vehicle and it works with the 1.2m cable, then you don't need the 30cm cable.
Time to create page: 0.554 seconds
