Hi all - New member
Hi all - New member was created by Jhil94
Posted 10 months 2 weeks ago #218730
Hi all
Just wanted to introduce myself, I don't own an MG but I'm doing some work on a friends 2005 tf.
I normally work on land rover's and other 4wd's. Looking for some electrical advice on the TF.
Josh
by Jhil94
Replied by Goodwood on topic Hi all - New member
Posted 10 months 2 weeks ago #218732
Welcome to the forum.
I think you will need to be more specific! What is your question?
Replied by Notanumber on topic Hi all - New member
Posted 10 months 2 weeks ago #218734
The circuit diagmas and original RAVE manuals can be found in the Library section. Its always worth reading through the How To's depending on what issues youve encountered.
The following user(s) said Thank You: Jhil94
Replied by Roverlike on topic Hi all - New member
Posted 10 months 2 weeks ago #218735
Replied by Cobber on topic Hi all - New member
Posted 10 months 2 weeks ago #218738
G'day and welcome to The-T-Bar. As a new member, you might benefit from having a look at our checklist for new owners/members:  https://www.the-t-bar.com/forum/54-how-tos/99326-a-check-list-for-new-owners  that should give you a headstart, before you need to ask specific questions.
Replied by Jhil94 on topic Hi all - New member
Posted 10 months 2 weeks ago #218744
Oh yes sorry, wasn't sure wether to post the question in a different category.
So I've got the common deadlock issue with both door latches, they're stuck shut and the central locking and the key in the door isn't doing anything inside the lock mechanism, I'm guessing the motors are seized but I don't understand why the key in the barrel isn't unlocking anything?
Has anyone had any luck getting the motors turning by bypassing the SCU and feeding straight to them?
Thanks
by Jhil94
Posted 10 months 2 weeks ago #218781
If both deadlocks are stuck on then you are right it must be the relay and if you remove the wires between there and the locks you can persuade them to open.
The superlock circuit is a real PITA in my view and i disconnect it from each F/ TF ive had. The good news is at least there's a clear way around it with the fault that you have rather than a failure of the lock mechanism.
Wiring colours are in the diagrams in the Library section. One of them is a brown wire with thin pink stripes (the one i always cut) but can't remember what the colour of the other one is, that is shared with the main lock
Last Edit:10 months 2 weeks ago by Notanumber
Last edit: 10 months 2 weeks ago by Notanumber.
Posted 10 months 2 weeks ago #218845
Ok Thanks, what does superlocked actually mean, also I've just managed to get the drivers side open by hitting the linkage arm down on the latch and it finally unlocked.
Took the mechanism out and took the motor out, theres a cherry type microswitch with three tiny buttons which detect when it's locked and shut, one of them doesn't seem to be making contact, could this effect the whole central locking on both sides?
Thanks
by Jhil94
Replied by Airportable on topic Hi all - New member
Posted 10 months 2 weeks ago #218847
Easily. The state of each switch & its interaction with the alarm/central locking control systems dictates the state of the alarm/lock mechanisms.
As with an ordinary mechanical lock, all the wards have to be in the correct place before a door is unlocked. The electronics is doing what the key is doing mechanically.
How good is your drawing? Could you draw the switch with measurements, overall dimensions, fixing centres, contact positions & plunger position.
As these switches are in all probability time expired, to be able to identify a replacement is going to extend the lock life for another twenty years, if a repair can be effective. There are a finite number of used locks left & new old stock won’t last for ever.
Thanks,
Posted 10 months 2 weeks ago #218848
Thanks for the quick response, I'll have to measure up all the internals. This is what the switch unit looks like (same as in a p38 range rover latch), one of the buttons has snapped and only clicks if pushed in with a pin.
Not sure how to insert the image actually.
Thanks
Last Edit:10 months 2 weeks ago by Jhil94
Last edit: 10 months 2 weeks ago by Jhil94.
Posted 10 months 1 week ago #218849
How to post pix:
Once you have clicked on the apply button. You will open the page you type your reply in.
Under your text window is another window with the heading:"Attachments"You can either drag and drop your picture into the box below or use the: "+ Add FIles" button to go into your file to find your pic.
Once you pic has been selected and it appears in the box below you will see a blue button below it: "Insert"  once you've clicked that it will go green and say : In Message"
don't click anything else but the blue "Submit" button below that window and your done.
Tips: use your retun button on your keyboard to create a space between your text and pic so so to make it all a bit easier to rea. and do the same between multiple pix for clarity.
Posted 10 months 1 week ago #218851
Am I right in thinking that if you have used the quick reply facility & you wish to add a picture, you have to transfer to editor.
This is how I have used the system to reasonably effect; my track record of picture embarrassments doesn’t detract from using this method.
Time to create page: 0.454 seconds
