My presentation and a problem about tyres
Replied by Airportable on topic My presentation and a problem about tyres
Posted 1 month 4 weeks ago #209484I have to say though that I would still be using Avon tyres, however they are no longer made in our sizes. The Avons performed & they lasted, I still have a front pair in good order as spares whilst much younger tyres are long gone.
I am in complete agreement with Cobb’s, especially about using certain tyres on wheel barrows.
Replied by Cobber on topic My presentation and a problem about tyres
Posted 1 month 4 weeks ago #209485As for the Falkens V Toyos.......you should be fine with either, really down to personal preference.
Replied by David Aiketgate on topic My presentation and a problem about tyres
Posted 1 month 3 weeks ago #209489I have used Nexen tyres on my F (although not those types)with very favourable results both with wet and dry grip, braking and wear rate. The last set of tyres were Falkens. Again, I was impressed with those.
I wouldn't advise using Linglongs either.
On the TF the pressures are pretty important, so check that as soon as possible.
On certain specials, like the F mk2 Freestyle, the standard tyres were 215/40/16xl all around so it was done by MGR. However the TF Suspension is very different from the F.
VERY IMPORTANT
It is vital that the rear tyres are XL load rated. The stronger tyre wall is necessary for handling. Ideally, I would recommend XL load rating for all 4 tyres.
- GalvanoBlu
- Novice MGer
Replied by GalvanoBlu on topic My presentation and a problem about tyres
Posted 1 month 1 week ago #209831I want to thank all the senior members who have helped in dissolving my doubts... thank you!!!
Replied by Notanumber on topic My presentation and a problem about tyres
Posted 1 month 1 week ago #209834Some pictures of your TF with it's new tyres please
- GalvanoBlu
- Novice MGer
Posted 1 month 1 week ago #209885But I would like to take this opportunity to ask you expert MGers... what kind of wheel does my car have? Yesterday I did some research: I looked through Roger Park's book, then on the internet, but I couldn't find them anywhere... they have the MG logo stamped on them but they don't appear anywhere, other than on my car.... has anyone ever seen them?
Posted 1 month 1 week ago #209888Which ever, we’ll done.
- GalvanoBlu
- Novice MGer
Posted 1 month 6 days ago #209924... I am impressed; in order to control the effective PCD of my wheels I have dismounted the MG plaque on the front and I have measured tohe distance between opposite bolts: 100 millimeters... (more exactly 8/100... there are eight holes on the rim and only 4 bolts fixed on the hub)
As Frenchs say... chapeau!!!!
Posted 1 month 6 days ago #209930I have commented on my odd bod wheels before, these are dual standard, one with our normal 95.25mm PCD & also 100mm.
I’m not sure whether these were around much a few years ago, if they were I hadn’t come across them until I bought my set. Yours set might be number two.
Replied by MGB281 on topic My presentation and a problem about tyres
Posted 1 month 6 days ago #209931Please Log in or Create an account to join the conversation.
Posted 1 month 6 days ago #209932You will be able to fit the studs without removing the hub, unless you choose longer studs, although a judicious amount grinding might be “advantageous”.
Posted 1 month 6 days ago #209940The trouble with this is the cost of the equipment is huge and then there is a lot of skill and knowledge needed to do it.
For me this is not a problem as I have the gear and have the trade background to do it, but for pretty well most of the rest of you, your better off leaving the old Black and Decker drill in it's box and taking the job to a proper machine shop. it is of course possible for some one with a bit less kit and and a high level of skill such as Airportable to do an acceptable job with great care. But for most blokes/blokettes this is a job best handballed to the pros. As this really is s safety issue, it can effect braking, handling and mechanical integrity.
I've even heard some people ask if they could slot the holes it the wheel to fit them to the hubs, the answer to this is NO! Doing this will only cause runout and balance problems as well as risking stud failure due to excessive load and for the fact that the wheel nuts probably won't ever stay tightened. Remember there is a lot happening with your wheel hubs when you are tootling up the road, there are great forces pulling and pushing in every possible direction simultaneously
