MGTF - No Dashboard Lights - Ignition Switch to II
Replied by LanderMG on topic MGTF - No Dashboard Lights - Ingition Switch to II
Posted 1 year 9 months ago #208677
Thank you.
I will start with the multimeter around the key-switch and connections and see if anything doesn't look right.
If I have to replace the key-switch, will I be able to switch the lock itself so I can keep the existing keys?
Replied by Airportable on topic MGTF - No Dashboard Lights - Ingition Switch to II
Posted 1 year 9 months ago #208678
There are one or two useful illustrations of the switch floating about on the internet. These are of value when sorting problems like this.
I’m going from memory here, which is rarely a good thing with me but search out Dieter’s web site. He has an early diagram of an f, this doesn’t look much like it’s successors but the basic key switch wiring is the same throughout the cars.
If I recall correctly, it had a block diagram of what connects to what as the key is turned; later diagrams omit this, again if the memory serves.
To others reading this, it is worth looking up Dieter’s site, some of it is inspired.
The following user(s) said Thank You: LanderMG
Replied by David Aiketgate on topic MGTF - No Dashboard Lights - Ingition Switch to II
Posted 1 year 9 months ago #208696
If I recall correctly, the electrical switch (black plastic unit) attaches to the bottom of the actual metal ignition switch, so the key mechanism remains the same😁
Yep, it's attached by 2 screws, so you can buy a second hand unit and swap your ignition barrel to the newer plastic connection.(If that is your problem, tbat is).
Last Edit:1 year 9 months ago by David Aiketgate
Last edit: 1 year 9 months ago by David Aiketgate. Reason: Pic and more info
Posted 1 year 9 months ago #208697
I think there are two patterns of switch, early & late (nowt like stating the obvious) & I don’t think you can graft one onto the other. Electrically they are identical, if buying a used part do make sure it’s off the same family group.
An early f & a 500 won’t mix.
Again this post starts with “I think” & so someone might like to verify, I have a switch in store which I think is a Mk2 / tf, I can’t check against a Mk1 as my car starts electronically & the key just enables the electronics, the rest of it fell in bits, hence the electronics.
Posted 1 year 9 months ago #208704
I’ve just been in stores & found this, it might help identify what you have.
this is off a Mk1, dated 25-06-98.
Replied by Notanumber on topic MGTF - No Dashboard Lights - Ingition Switch to II
Posted 1 year 9 months ago #208729
It's very easy to change the switch part on the back of the ignition lock. Just 2 screws
Replied by henrythompson on topic MGTF - No Dashboard Lights - Ingition Switch to II
Posted 1 year 9 months ago #208895
Hello,
As per me, the fact that the car starts intermittently and the dash lights don’t always come on points to a potential electrical connection problem. Check for any moisture or corrosion around the ignition switch, and ensure the wiring harness is secure. It’s also worth inspecting the fuses and relays for any signs of water damage. If the problem persists, the ignition barrel itself might need replacing.
Thanks
Posted 1 year 8 months ago #208983
What has HenryThompson done I wonder to get banned. The words of the immortal John Cleese came to mind whilst reading his post, "Specialist subject the bleeding obvious"  but seemed unlikely to have otherwise got up anyone's nose and his 2 other posts were fine.
Last Edit:1 year 8 months ago by Notanumber
Last edit: 1 year 8 months ago by Notanumber.
Replied by Cobber on topic MGTF - No Dashboard Lights - Ingition Switch to II
Posted 1 year 8 months ago #208992
AI spam-bot
They're using new tactics to infiltrate, they set themselves up with some seemingly innocent posts to try and get you to think that they're genuine,  then they do a post that on the surface seems relevant but actually contains a spam link that has nothing to do with what the subject matter is. All hallmarks of an AI spam-bot
He's/her's/It's phrasing was a bit odd and the answers and advice was fairly generic, we were watching them from the outset, waiting of them to go in for the sell.
Your moderation and admin team are on the ball and will act when we  deem it necessary. Sadly there will be more of this and they will get better at it and harder to pick!
Replied by bluebae on topic MGTF - No Dashboard Lights - Ignition Switch to II
Posted 1 year 8 months ago #209008
Not sure if this is helpful, but have you tried disconnecting the battery for a few minutes and then reconnecting it? Sometimes that can reset things and solve weird electrical issues.
by bluebae
Replied by Notanumber on topic MGTF - No Dashboard Lights - Ignition Switch to II
Posted 1 year 8 months ago #209164
Was this resolved.
Are you back seeing paradise by the dashboard light ?
Replied by LanderMG on topic MGTF - No Dashboard Lights - Ignition Switch to II
Posted 1 year 8 months ago #209221
Hi,
So..... I disconnected the battery several times and still no joy. However, what I did was by chance and seems to have 'fixed' the issue.
It seemed that when rear speakers were added, the problem seemed to appear. Removed the centre air vents and sure enough, all the radio wires were squeezed between radio and cross bar. Repositioning these wires onto of the radio, and ensuring there was no exposed copper seemed to fix the issue.
So now when she goes to start the car, it all seems fine. Not heard of that before but moving these cables seems to have done the trick. Strange one.
Thank you for all the tips, and who knows, maybe i will need to get a new switch, but for now she seems happy.
Time to create page: 0.430 seconds
