flat and polish - what's the trick ?
Replied by Red110 on topic flat and polish - what's the trick ?
Posted 1 year 3 weeks ago #216376
by Red110
Replied by D4KGP on topic flat and polish - what's the trick ?
Posted 1 year 2 weeks ago #216723
Hi I'm now having the same problem that you experienced with the two can system. So have you solved the problem you were grappling with on this paint/gloss issue? I'm beginning to wish I'd gone with just a single can mix the same as when I done a small job on my F. Glyn.
Replied by Notanumber on topic flat and polish - what's the trick ?
Posted 1 year 2 weeks ago #216747
I gave up, flattened it down again and went over it again with the remainder of the base coat can. Then I ordered a can of single coat gloss which provided much better results immediately.
Im starting to wonder if it's the high temperature which is working against us with the seperate laquer coat. Perhaps the laquer is drying immediately on contact with the bodywork which is making it matte straight away.
Last Edit:1 year 2 weeks ago by Notanumber
Last edit: 1 year 2 weeks ago by Notanumber.
Posted 1 year 2 weeks ago #216751
Thanks for replying, that's exactly what I'm thinking of doing now, as I had a reasonable degree of success with the single can on the F. As you say it could be to do with the hot weather. G
Time to create page: 0.379 seconds
