Failed Electric Window
Failed Electric Window was created by neilpinleeds
Posted 2 months 4 days ago #223333
After years of being slow and noisy my drivers side window has finally given up the ghost. It will very slowly lower, but when you try to raise it there is just a grinding sound. I was able to drag it back to the top bar 5mm manually.
Surprisingly there doesn't seem to be a guide on replacing the mechanism on the Forum (may have missed it?)?
Somehow I don't think this is because its so obviously easy.....
Any advice welcome.
Neil
Replied by Notanumber on topic Failed Electric Window
Posted 2 months 4 days ago #223335
"After years of being slow and noisy"  I think you are being too harsh on yourself a bit there Neill.
 This is what you need assuming yours is a Mk2 F or a TF. I cant remember what your car is   https://www.mgfntfbitz.co.uk/shop/rh-window-regulator-assembly/   Mk1 F's used a slightly different type.  Window regulators can look very perplexing but when you have the door card off and hold the replacement part up to the door before you start undoing anything it immediately starts making sense as you can then see how it works and what goes where.
Last Edit:2 months 4 days ago by Notanumber
Last edit: 2 months 4 days ago by Notanumber.
Replied by neilpinleeds on topic Failed Electric Window
Posted 2 months 4 days ago #223337
Thanks, yes, 2004 TF....
Replied by judiths handyman on topic Failed Electric Window
Posted 2 months 3 days ago #223343
I take it the motor has given up the ghost.
Mine was getting slower and I liberally lubricated the guides and slides which helped.
The following user(s) said Thank You: neilpinleeds
Replied by Airportable on topic Failed Electric Window
Posted 2 months 3 days ago #223346
Your car will have the one shot windows, which I believe is operated by the Pektron unit. Very early cars were not blessed with this facility, later Lucas cars had a control unit in the drivers footwell; these got damp & some were prone to high resistance relay contact failure, this caused slow operation. It could be the same with the Pektron unit, especially when one considers the other problems caused by those relays.
I retro fitted the Lucas unit in my early car, however being aware of other problems I relocated my unit, (modified & sealed) in the door.
Posted 2 months 3 days ago #223350
Thankfuly good 2nd hand ones are not extortionate and they are not tat difficult a job to change
Replied by mowog73 on topic Failed Electric Window
Posted 2 months 2 days ago #223371
As an FYI, the window motors from a LR Discovery 1, CUR100450 and CUR100440, are identical to the ones used in MGFs and TFs, and the connector is the same as the one used on early MGFs; no need to switch connectors.
[size=10pt]Mark[/size]
95 MGF
by mowog73
The following user(s) said Thank You: R40MGF, neilpinleeds, Red110, TA22GT
Time to create page: 0.448 seconds
