Interior Mirror Adhesive Pad
- Wild Rover
- Apprentice MGer
I have tried 2 'Pearl' Mirror adhesive pads.
They claimed to be heavy duty but despite me thoroughly cleaning both surfaces, they couldn't hold the weight of the mirror, for very long.
I even tried by sticking the pad to the metal plate, leaving it 24hours, then sticking the metal plate to the screen and leaving it 24hours then attaching the mirror to the plate,. (It would hold for a few hour's, then fall away, leaving the pad stuck to the screen.
Does anyone know of a product that can cope with the weight of our mirrors?
Thank you.
- generous_dad
This was fine as I had not counted on being able to save either the mirror mount or the screen so this was idle curiosity at it's destructive best, As far as I could see it had been glued in place by something that looked very much like black windscreen sealant.
This stuff impressed me so much that when I needed to buy some sealant to reseal around the outside facing edges of a glass panel in a sliding patio door I bought windscreen sealant on a whim rather than the usual silicone stuff. Though its properties could be described in similar terms, remaining flexible etc, it really is in quite a different league for adhesion and IMHO definitely worth the extra cost.
- judiths handyman
Replied by judiths handyman on topic Interior Mirror Adhesive Pad
Posted 1 month 2 weeks ago #223680https://www.3m.co.uk/3M/en_GB/bonding-and-assembly-uk/double-sided-tape/
- Wild Rover
- Apprentice MGer
- Wild Rover
- Apprentice MGer
The days of being able to easily buy from an industrial chemist, “super solvents” such as trichloroethane or carbon tetrochloride, both of which would take the shell of a tortoise, are long gone
[size=10pt]Mark[/size]
95 MGF
- Wild Rover
- Apprentice MGer
For anyone else with this problem I originally posted about, the solution I tried and was successful with, was using 'Locktight 'Rear View Mirror Adhesive 319'.
It comes as a glue, with a gauze which you cut to size.
I slid the metal back plate out of the mirror, cleaned both windscreen and metal plate using acetone nail varnish remover, washed it again with water.
Once it dried, I cut the gauze to the shape of the metal plate, applied Adhesive, placed the gauze on top of the Adhesive, lined the plate up paralell to the shaded area on the windscreen, pressed the loaded plate to the screen for a minute, then left the bond to cure for 2 days, before reattaching the mirror to the plate.
Its held firm for a week now, despite some really hot weather.
Thanks to everyone who contributed to the solution.
