Gearbox Doesn't fit
- blackislegypsy
- Novice MGer
- blackislegypsy
- Novice MGer
Some ham fisted ape has buggered something up and did a dodgy with the washers to try and fix thier monumental cock up!
You'll need to seperate the gearbox from the engine again.
Check the spigot bearing in the crankshaft that supports the gearbox input shaft is in good condition and properly in place and not jamming the shaft.
Check the spilnes on the gearbox input shaft are in good conditon and the clutch plate slides on properly.
I trust you've used a clutch alingment tool before bolting the clutch pressure plate to the flywheel with a torque wrench to specifications?
Now once these checks have been done and proved to be Ok, the next thing that occurs to me is the posiblity that either the gearbox or engine has been rebuilt at some stage and either the gearbox input shaft is sticking out too far forward due to incorrect assembly on the flywheel is somehow sitting too far aft, though gwad only knows how!
I suspect that what is happening is: As you try and bolt the gearbag to the engine the the input shaft is pressing against the clutch, flywheel of the crankshaft causing binding.
The flat side goes against the flywheel.
The wrong way round and the centre of the clurch plate rests on the spigot bearing.
The clutch wouldn't disengage.
If it has been driving it cant be that.
Actually on some car the clutch will work to some extent if the clutch has been fitted arse about, I recall a Ford Escort van with the 1.6 that came in with a buggered clutch. The owner had replaced the clutch himself, but it was working strange and was making horrible noises, so he bought it in, for us to sort out.I'm not sure if the car has been driving like this but if it is just a new clutch that has been fitted the plate itself could be in the wrong way. There is a flat side and a deep side.
I turns out the stupid bugger had put the friction plate in backwards!
I'm surprised it worked at all, but it did in a fashion, just not a fashion that should catch on......the friction plate was buggered!
- blackislegypsy
- Novice MGer
- blackislegypsy
- Novice MGer
If some of the bolts do not fit / match up, then the bell housing at least must be wrong. A chunk of the engine snapped off suggests someone has attempted to close the gap by heaving on the mounting bolts. Nasty! What else have they done would be my worry.
The variety of boxes and engine variant is way beyond my knowledge.
I take it you have just acquired this car?
[size=10pt]Mark[/size]
95 MGF
- blackislegypsy
- Novice MGer
