Gearbox Doesn't fit
Gearbox Doesn't fit was created by blackislegypsy
Posted 5 days 11 hours ago #224445
Now , theres a gap of 4 or 5 mm, caused by washers being used as spacers on all the bolts even on the bolts on the two dowels. The dowels therefore are having no effect at all. Gearbox off and all the washers fell onto the ground. I thought it might have been a remedy trying to cure the stuck release arm. New 3 piece clutch on, arm freed off nicely. gearbox on first time and bolts in but wont tighten the last 4mm and the flywheel wont turn, slacken them off and the flywheel turns. It would appear to need the washers re-fitted! Whats that all about?
Last Edit:5 days 11 hours ago by blackislegypsy
Last edit: 5 days 11 hours ago by blackislegypsy.
Replied by blackislegypsy on topic Gearbox Doesn't fit
Posted 5 days 11 hours ago #224446
Half of that is
Replied by Cobber on topic Gearbox Doesn't fit
Posted 5 days 11 hours ago #224447
Not sure what's going on there, but I can say that there is somrthing horribly wrong going on there.
Some ham fisted ape has buggered something up and did a dodgy with the washers to try and fix thier monumental cock up!
You'll need to seperate the gearbox from the engine again.
Check the spigot bearing in the crankshaft that supports the gearbox input shaft is in good condition and properly in place and not jamming the shaft.
Check the spilnes on the gearbox input shaft are in good conditon and the clutch plate slides on properly.
I trust you've used a clutch alingment tool before bolting the clutch pressure plate to the flywheel with a torque wrench to specifications?
Now once these checks have been done and proved to be Ok, the next thing that occurs to me is the posiblity that either the gearbox or engine has been rebuilt at some stage and either the gearbox input shaft is sticking out too far forward due to incorrect assembly on the flywheel is somehow sitting too far aft, though gwad only knows how!
I suspect that what is happening is: As you try and bolt the gearbag to the engine the the input shaft is pressing against the clutch, flywheel of the crankshaft causing binding.
Last Edit:5 days 11 hours ago by Cobber
Last edit: 5 days 11 hours ago by Cobber.
The following user(s) said Thank You: blackislegypsy
Replied by Notanumber on topic Gearbox Doesn't fit
Posted 4 days 17 hours ago #224470
+1 for it to either be the input shaft sticking out too far in relation to the gearbox casing or a manual gled spigot bearing in the end of the crank. First off could be to remove the spigot bearing to check its fine and theres nothing perhaps wedged behind it.
  • TA22GT
  • Away
Replied by TA22GT on topic Gearbox Doesn't fit
Posted 4 days 15 hours ago #224476
I'm not sure if the car has been driving like this but if it is just a new clutch that has been fitted the plate itself could be in the wrong way. There is a flat side and a deep side.
The flat side goes against the flywheel.
The wrong way round and the centre of the clurch plate rests on the spigot bearing.
The clutch wouldn't disengage.
If it has been driving it cant be that.
Posted 4 days 13 hours ago #224483
Actually on some car the clutch will work to some extent if the clutch has been fitted arse about, I recall a Ford Escort van with the 1.6 that  came in with a buggered clutch. The owner had replaced the clutch himself, but it was working strange and was making horrible noises, so he bought it in, for us to sort out.
I turns out the stupid bugger had put the friction plate in backwards!
I'm surprised it worked at all, but it did in a fashion, just not a fashion that should catch on......the friction plate was buggered!
Replied by VinceR on topic Gearbox Doesn't fit
Posted 4 days 8 hours ago #224487
I suppose there is no chance that someone has bodged on the wrong GBox that was not intended for a TF?
by VinceR
Posted 2 days 1 hour ago #224528
Now , wrong gearbox came up in conversation an hour (with all the spacer washers falling out) the rearmost M10 bolt at the bottom beside the exhaust came out with a large chunk of the engine 'we will have to do without that then, unless I TIG it back on'! When I inspected the chunk I noticed that a second hole had been drilled alongside the original. Not sure which hole was being used for the bolt but that might be another indicator that somebody had been struggling to get this gearbox to fit. Spacers??? Extra hole drilled. Also there was two bolts missing for no good reason and only one nut on the starter bolts!
Posted 2 days 1 hour ago #224529
Is there such a gearbox which would suit all the mountings except not go all the way on and the rearmost bottom thread be slightly in the wrong place?
Posted 1 day 15 hours ago #224536
Grief!  Difficult to know where to start.
If some of the bolts do not fit / match up, then the bell housing at least must be wrong. A chunk of the engine snapped off suggests someone has attempted to close the gap by heaving on the mounting bolts.  Nasty!  What else have they done would be my worry.
The variety of boxes and engine variant is way beyond my knowledge.
I take it you have just acquired this car?
Last Edit:1 day 14 hours ago by VinceR
Last edit: 1 day 14 hours ago by VinceR.
Replied by mowog73 on topic Gearbox Doesn't fit
Posted 1 day 8 hours ago #224540
Are you sure you have it lined up correctly? When I had the gearbox separated from the engine to install a new clutch, when I pushed the two back together and started bolting the gearbox back on, I found a few bolts wouldn't go in, turned out I have the gear box aligned improperly. I unbolted it, readjusted it, ie got it properly aligned, and all the bolts went back in.
[size=10pt]Mark[/size]
95 MGF
by mowog73
Posted 9 hours 44 minutes ago #224550
Ok. Took the gearbox back   end of the shaft is 18mm and the hole in the crank is 13mm. is it the wrong gearbox or wrong engine?
Time to create page: 0.421 seconds
