Recommended Tyres for my MGF
Recommended Tyres for my MGF was created by dg170775
Posted 13 years 8 months ago #21666
Hi,
I'm new here, but, I would like some recommendations for tyres on my MGF.
I have a 2000 'V' Reg MGF, and the front and rear tyre spec is 185/55 R15 82V and 205/50 R15 86V respectively.
I will be really grateful if you folks can recommend some tyre options, that are suited for the MGF.
Regards.
Replied by teri on topic Re: Recommended Tyres for my MGF
Posted 13 years 8 months ago #21667
First off welcome to the T Bar, hope you enjoy your stop and look forward to more posts from you.. BTW photo's are a must round here or the ninja's will be after you ;)
As for tyres, alot of people use the Toyo Proxy's or the Goodyear Eagle GSD2 I think.... Someone like David will be along and tell you more...
Tigger my MK2 F has the Toyo's on :)
Angel to Devil in 0.2 seconds...[SIGPIC][/SIGPIC]
David Aiketgate;17095 wrote: Oi, stop using foul language or I'll give you one!
by teri
Replied by David Aiketgate on topic Re: Recommended Tyres for my MGF
Posted 13 years 8 months ago #21668
:welcome2:
Have a look here!
TYRES
ToyosT1 Rs are highly regarded. My personal preference is for Nexen 2000 for 15" and Nexen 6000 for 16" wheels.
Last Edit:13 years 8 months ago by David Aiketgate
Last edit: 13 years 8 months ago by David Aiketgate.
Replied by dg170775 on topic Re: Recommended Tyres for my MGF
Posted 13 years 8 months ago #21669
Hey David, thanks a lot for the quick info...
I tried the link you have mentioned but I'm able to see only half the table .. and content's not clear ..
Any other options....?
Sorry, can see the list now .. Needed IE :)
I see in the list that you've adviced to Avoid Pirelli P6000, whereas my car came with 4 absolutely new P6000s :) What's the major issues with Pirellis, I thought thy're a good brand ...
Last Edit:13 years 8 months ago by dg170775
Last edit: 13 years 8 months ago by dg170775. Reason: Added Info..
Replied by adamelphick on topic Re: Recommended Tyres for my MGF
Posted 13 years 8 months ago #21674
Hi and welcome!!
I have used Falken 452's 16" on Meg for the last 5 years and love them to bits. Good grip and look nice. Wear well too - in 5 years I have had to replace only the rears!
Posted 13 years 8 months ago #21675
dg170775 wrote: Hey David, thanks a lot for the quick info...
Those recommendations or otherwise were gathered from actual mgf/Tf users and Continentals and the Pirelli 6000s were slagged off by several people.
Sometimes, though people have /tracking issues and blame the tyres.
I'd be interested to hear your views on the Pirelli 6000s, it may be that the tyres were not to blame in the mentioned reports. They were recorded as 'Ditchfinders'!
Posted 13 years 8 months ago #21678
Well, now that you mention, I have noticed a few times that when I take a round about aggressively, I have lost grip completely at the front ..
But, I just assumed that this was normal in a light car..
Secondly, it's generally my better half doing most of the driving..
And the Car had been quite uncontrollable in the snow we had end of 2010, but, again I assumed that the car is at fault, as it's too light & small.. Sorry, am not an expert on cars :(
Posted 13 years 8 months ago #21679
dg170775 wrote: Well, now that you mention, I have noticed a few times that when I take a round about aggressively, I have lost grip completely at the front ..
If the F is setup correctly with good tyres, there's not much that will grip better!
The only problem with front end is lift at speed, which is solved with a front splitter.
If you're getting understeer on roundabouts, something's not right. If anything it's oversteer you have to be careful about.
Posted 13 years 8 months ago #21680
Hmmm.. interesting.. I'm taking it tomorrow to the tyre shop to check how many of the tyres will need replacing..
And if required I'll replace the tyres in pairs..
And also get the tracking done ..
A brisk driving then should explain a few things ..
I'll post the updates ..
Replied by Tigger on topic Re: Recommended Tyres for my MGF
Posted 13 years 8 months ago #21681
Seem to remember reading somewhere that the problem with the Pirellis was lack of wall reinforcement.
Certainly shouldn't be having front end problems at low speed. Have used mine throughout the winter, as David said it's the rear that can step out - recommend the Falkens myself although mine are on 17" rims, don't know if that's a factor.
by Tigger
Replied by rough luck on topic Re: Recommended Tyres for my MGF
Posted 13 years 8 months ago #21687
For good all round use and a mid range price I go for Federal on mine, but then again I'm on 215/35/18's
a real bone shaker ride, but have driven 30 miles with a flat an didn't even notice, so can be handy...lol
Replied by bryan young on topic Re: Recommended Tyres for my MGF
Posted 13 years 8 months ago #21700
The MGF is very tyre sensitive and were originally designed to run on Goodyear's ONLY, before rushing off to the tyre shop and getting new tyres that may be totally unsuitable and make the handling worse. Please give us some more information so you can be given good advice. What tyres are on there at the moment?? i notice that Tigger mentions Pirelli :shrug: :evil: they are to be avoided at all costs!!!!!! mixing different makes of tyre can make the handling a nightmare and running at the incorrect pressures makes a weird feeling. You know the sizes are different front and rear and all four wheels have to be tracked at the same time (yes the rears have to be adjusted too. Is the ride height correct ? (the suspension pumped up) there are compliance washers on the rear suspension links which wear and allow the rear wheels to self steer. is the EPAS ok or does it pull to the left when starting the engine??
As David has said the correct tyres and suspension set up will give you superb handling and the car will "stick like glue"
Please give us loads of information and we will advise you correctly. :whistle:
Time to create page: 0.560 seconds
