Replied by talkingcars on topic Re:Wocha bin doin on your MG this week then?
Posted 4 years 9 months ago #192482SRS ECU on modified* mount bolted in.
Gear box end of cables attached.
Only got 1,3 and 5 and notchy.
2 3/4 turns on the short cable and ran out of twists when I wanted 3.
Turned it back 3/4 of a turn.
Yah, all 6 gears and such a nice feel.
*I trimmed the top face so one can get to the front bolt of the gear lever mechanism and so all my additional wiring (heated seats/under seat amp/CD changer) can pass under and up.
Posted 4 years 9 months ago #192491Took her round the block, clutch bite is low but I guess it needs bleeding, other than that she goes.
Replied by Raccoon on topic Re:Wocha bin doin on your MG this week then?
Posted 4 years 9 months ago #192492talkingcars wrote: She runs....
YEAH! :broon:
Replied by David Aiketgate on topic Re:Wocha bin doin on your MG this week then?
Posted 4 years 9 months ago #192494David
Posted 4 years 9 months ago #192495
Replied by Fiddler on topic Re:Wocha bin doin on your MG this week then?
Posted 4 years 9 months ago #192518Anyone near Liverpool and update with local meetings Too cold to work on F .
M G C to do for friend as well .
Replied by Gavin207 on topic Re:Wocha bin doin on your MG this week then?
Posted 4 years 8 months ago #192670Please Log in or Create an account to join the conversation.
Posted 4 years 8 months ago #192680I went for a test run to see if the clutch was bleed properly.
Got back and stopped outside on the road. I went to move her on to the drive and she started fine but wouldn't tickover, and the rad fan was on. I guessed the CTS sensor wasn't working properly (although it was reading correctly in pscan) so I changed the sensor. I still had the same symptoms.
Gut feeling said IVAC so I took it out and tried starting her again. She ticked over at 2000 rpm. I wiped the IVAC and refitted to find a steady tickover which slowly climbed in line with coolant temp so the IVAC needs a proper clean up.
But why is the radiator fan running constantly?
Posted 4 years 8 months ago #192682David
Posted 4 years 8 months ago #192684David Aiketgate wrote: Faulty coolant sensor?
I hope not as I was getting the OBD reading through the pscan and I replaced the CTS for a new one with no difference.
- SundanceUK
Replied by SundanceUK on topic Wocha bin doin on your MG this week then?
Posted 4 years 8 months ago #192707Looking even better than the first time I did them!
I will get round to sealing them in shortly, but car is off to the bodyshop for some more rust spot treatment, including the boot lip corner, so will re-seal the lights back in when the paintwork has been finished.
The 3 light unit Lexus type rear lights have to be sealed in with a sealant, otherwise they will allow water to come in to the boot.
Sundance
- mgtfbluestreak
Posted 4 years 8 months ago #192738Please Log in or Create an account to join the conversation.
