Replied by Fiddler on topic Wocha bin doin on your MG this week then?
Posted 4 years 6 months ago #193148
Head gasket all back together and running . Great sound ..Ran for a few mins without exhaust . Need ex man gasket
That tensioner is a pain to re set
Just for information is a new auto tensioner locked in OFF position for Installation?
Helping refurb MGC NO NIGHTMARES!!
by Fiddler
Replied by Robman on topic Wocha bin doin on your MG this week then?
Posted 4 years 6 months ago #193151
I finished putting aluminium coolant pipes under my F The old ones had a pin hole in one of them. I had to flare the pipe as the first time I did it the rubber hose just slipped off when it got up to temp & pressure. I did it in 4 pieces of tube & just used the rubber for the bends in the front, I was able to throw a fair bit of the rubber hose out & made the tube go closer to the radiator. It should add to the cooling capacity as well.
I cleaned the radiator out too it probably only had 60% of its tubes open. I used a long piece of copper to push gunk out.
by Robman
Replied by Postman87 on topic Wocha bin doin on your MG this week then?
Posted 4 years 6 months ago #193289
Got of to a very slow start on my restoration due to a few reasons, but finally got back on track.
Put my front sub-frame in for sandblasting and managed to get it back before lock-down. All the other parts i sandblasted myself primed and painted during this week. Still got the hubs to do but should get this done once i get more blast media. More than happy with the results.
I've started on the bodywork today,cutting out a rusty section from the rear wheel arch and sill. Intention was to repair it then weld it back in. Unfortunately it was to far gone so I've made a trial run on fabricating a replacement section. It's turned out not to bad but will need a bit more work.
Wife and i should have been in New York this week. Still had the week off so thought I'd make good use of it.
Last Edit:4 years 6 months ago by Postman87
Last edit: 4 years 6 months ago by Postman87.
The following user(s) said Thank You: SundanceUK
Replied by Fisher on topic Wocha bin doin on your MG this week then?
Posted 4 years 6 months ago #193292
Just returned from the MOT station........ Passed again! Another year of carefree motoring in my 2004 TF.
by Fisher
Posted 4 years 5 months ago #193301
Good to see MOT pass .My F running good PO had plug leads wrong way .that is the flying leads they are now far from its coil pack . I know all about lost spark .so front coil lead goes to 4
Coil pack 3 goes to 2 .
before it was
1 coil 2 lead. 3 coil 4 lead are we goin mad?
Head gasket replacement looks good at the moment no thermostat just the open blank . PRT in later .this week
Good battery looks like the secret of good starting
Last Edit:4 years 5 months ago by Fiddler
Last edit: 4 years 5 months ago by Fiddler. Reason: Adding info
Posted 4 years 5 months ago #193314
Changed the inlet stepper motor in a bid to sort the veriable tickover but not tested it.
Replaced the rear n/s control arm but not tested it.
Noticed one of the exhaust down pipes is touching the subframe but not fixed it
Noticed both silencer mounts need attention but not done anything about it.
Replied by MGmike on topic Wocha bin doin on your MG this week then?
Posted 4 years 5 months ago #193331
MOT passed... first one in fifteen years!!!!!
Left it at the garage to have the wheel alignment done after the rear sub-frame overhaul but will be taxed on 1/6/20 and hopefully the sun will hang around for a few weeks....
Now to make the interior a place I want to be.....
by MGmike
The following user(s) said Thank You: talkingcars, sworkscooper, SundanceUK, Fisher
Posted 4 years 5 months ago #193446
PRT fitted up front with 32mm t piece and 32mm silicone rad hose . Hope all is ok .car ran up to temperature .Changed oil and filter .old .oil a bit like coffee with HGF water mixed . It had only done one mile might be good for lathe cutting fluid .Drill coolant.
Can any one tell me exactly where a hose
Restrictor goes in the one .(which one)
Out of the engine helps temperature switch on rad fan .Near the sensors in
Outlet.
by Fiddler
Posted 4 years 5 months ago #193447
Sorry mate, most of that doesn't make sense.
Posted 4 years 5 months ago #193463
Sorry to be confusing .No need info as all running well .Temperature very steady .
Next job fit Ali radiator and replace n.s headlight
by Fiddler
Posted 4 years 5 months ago #193562
Bad clearcoat damage peeling only on bonnet. Removed with abrasive orbital discs . So will be spraying barcoat sealer primer and 2k solar red .all other panels are ok . Anyone stripped back to bare metal ? With paint stripper ? Might be quicker
by Fiddler
Posted 4 years 5 months ago #193563
Sorry most things I talk about don't make sense. Look through the drivel !
by Fiddler
Time to create page: 0.927 seconds
