Replied by Fiddler on topic Wocha bin doin on your MG this week then?
Posted 4 years 6 months ago #193036Changed oil /filter Cleaned underneath and brushed on VACTAN rust converter
After dried waxoyl spray underneath
Quick interior wipe over M O T check tmorow pray for brakes and gas analysis
ok .Saturday 25 April 20 in Liverpool .after fitting new inlet gasket doing HGF so lots of fun .water pump and belts have been changed in the near past so will report just change head gasket and bolts. Car did drive really good for half a mile .love the steptronic and electric pas
Posted 4 years 6 months ago #193037Can you undo ex manifold and move out of the way when head removal .Or do you have to remove from pipe completely .? Looks Iike there's room
Posted 4 years 6 months ago #193038Please Log in or Create an account to join the conversation.
Posted 4 years 6 months ago #193041
Posted 4 years 6 months ago #193045Fiddler wrote: ......Can you undo ex manifold and move out of the way when head removal.........Looks Iike there's room
There's room.
Posted 4 years 6 months ago #193046
Posted 4 years 6 months ago #193055The gasket had been changed also by PO.
Thermostat also stuck shut .tested and no good .Advice needed should I fit the new position stat? metal pipes to stat housing removed need refurb or replace.
The c shaft sprocket dowels were just spring tubes and lots of play ./adjustment if you call it that .small g+t needed .
Posted 4 years 6 months ago #193060Fiddler wrote: …….Thermostat also stuck shut .tested and no good .Advice needed should I fit the new position stat? metal pipes to stat housing removed need refurb or replace....
Do you mean the PRT?
They are more efficient than the old style.
Posted 4 years 6 months ago #193067Cleaned and painted water pipes pipes .that go under in manifold .cleaning off block/head surfaces. Tapped out ex stud holes .nice new studs to go in .
Enjoying not how think "how do you do this" But advice cam spring pins very loose so cam sprocket fit not radially accurate .Will make better pins 6mm and good fit .
Posted 4 years 6 months ago #193087
Replied by davidgv1 on topic Wocha bin doin on your MG this week then?
Posted 4 years 6 months ago #193089Please Log in or Create an account to join the conversation.
Replied by Gavin207 on topic Wocha bin doin on your MG this week then?
Posted 4 years 6 months ago #193102Please Log in or Create an account to join the conversation.
