Replied by cairnsys on topic Re:Wocha bin doin on your MG this week then?
Posted 7 years 5 months ago #178243If not I'll be back looking for suggestions!
Robin
Replied by Steve on topic Re:RE: Re:Wocha bin doin on your MG this week then?
Posted 7 years 5 months ago #178256Wynns hydraulic valve treatment, add that to your fresh oil, brilliant stuff the only oil additive I ever use and does what it says on the tin.cairnsys wrote: Changed the oil and filter. Not sure it really needed doing but I've developed a 'tappety' noise at start up which goes away after a couple of minutes idle. I'm hoping that changing the oil may resolve this.
Sent from my SM-J500FN using Tapatalk
Replied by c.steffan on topic Wocha bin doin on your MG this week then?
Posted 7 years 5 months ago #178261Recently waiting for the securing clips of the drive shafts. Than I can start to reassemble the lot.
A view of our carport:
BTW: a big thank to CJJ as I'm following his great how-tos!
Regards
Christof
Replied by helsbyman on topic Wocha bin doin on your MG this week then?
Posted 7 years 5 months ago #178268After a good sanding which got rid of 90% of the rust I put on hammerite cure rust which got rid of the rest. I then used hammerite dark green paint [ all most brg ] to finish it off
Posted 7 years 5 months ago #178287
Replied by stevew on topic Wocha bin doin on your MG this week then?
Posted 7 years 5 months ago #178445:beer: :beer: Steve
- Rich in Vancouver
Replied by Rich in Vancouver on topic Wocha bin doin on your MG this week then?
Posted 7 years 5 months ago #178446Last year I bought a rare NOS alloy hardtop that Mike Satur discovered in his warehouse
while moving premises. My plan is to mount it on the car for shows. I'll remove the soft top
and fit a lexan panel in place of the engine cover. This should lessen the constant stream of
"How do you work on the engine" questions.
At this point the hardtop is primed, and after a wet sanding will be ready for paint this weekend.
Fingers are crossed that my efforts at bodywork will be acceptable.
Posted 7 years 5 months ago #178451But first I'll have to do the night shift (six nights) and work on her every afternoon.
Regards
Christof
- Maddog1950
- Journeyman MGer
Replied by Maddog1950 on topic Wocha bin doin on your MG this week then?
Posted 7 years 5 months ago #178514Today I've made a new flow restrictor for cooling system, turned an aluminium spacer to fit neatly into the steel coolant rail, hopefully with the coolant it won't corrode.
Now I just need to get a new gasket for inlet manifold and I'm ready to give the car a service, I think I've got everything ready now.
I quite want to fit the x-power exhaust, but might do that later as I'm eyeing up heat insulation options for between exhaust and boot, but not sure I can wait.
- mgtfbluestreak
Posted 7 years 5 months ago #178540Please Log in or Create an account to join the conversation.
- SundanceUK
Replied by SundanceUK on topic Wocha bin doin on your MG this week then?
Posted 7 years 5 months ago #178543Oooh . ...how much how much?mgtfbluestreak wrote: Bought and fitted some new cantrial seals from mgobsession
Posted 7 years 5 months ago #178551UpdateDavid Aiketgate wrote: I replaced the ECU coolant temp sensor in the hope of curing the almost constant running rad fan. Also found the wire to the temp gauge plug hanging on by one strand, so renewed that too.
I noticed that the engine bay fan wasn't connected either! Reconnected that and tested it. Working fine!:yesnod:
I've also noticed the fuel consumption figure has dropped to around 33.5 per gallon , so I'm hopeful that the new temp sensor will see that figure improve.:pop:
The car is now averaging just over 40 mpg, doing exactly the same driving runs.:woo2:
Goes to show the improvement a new ecu coolant temp sensor can make!
