brake master cylinder
Il order them today.
Who wants one / more than one ? So far Ive got
Generous_dad X1
Red110 X1
Notanumber X1
Mowog ??
Airportable ??
Thanks for asking Notanumber, but I happen to have a couple brake master cylinder rebuilt kits sitting on the spares shelf already.
[size=10pt]Mark[/size]
95 MGF
- trevtherevs
- Apprentice MGer
If I commit & it isn’t compatible I’ll end up with another white elephant to add to the zoo
Union sizes are a question, my tools will only cope with cupronickel alloy (I must get it back from my brother) & I seem to recall the pipe work is steel.
I realise it’s a numbers thing, unfortunately I can’t guarantee to join your collective.
Good hunting.
Are you suggesting not to do the group buy of 5 of these then ?
Part NumberSJC000040
Specifically offered for very late MG Rover MGTF (Oct 2004 - March 2005 built) and NAC/SAIC MGTF models. These cars used a different brake master cylinder and servo to the earlier MG Rover built cars. The SJC000040 is aluminium (silver). The earlier MG Rover MGTFs use SJC000150 which is a pressed steel black coated master cylinders, these have not been availble for some years (second-hand only)
As a nosey bugger first class, with honours & bar, I’d like to do a comparison as some clever Bugger might be able to work out a work around.
There will come a time & before all the petrol runs out that this mod could be required & to be fore warned is to be fore armed.
Mind you you’ll still have to stop even if you’ve converted to clockwork or electric as you’ll not be able to rely on regenerative braking or rewinding your spring whilst coming to a holt.
- trevtherevs
- Apprentice MGer
I would be delighted if someone can come up with something, my solution was to wait until i could find a LE servo but that seems impossible or at least what I'm prepared to pay.
Another possibility is the maybe the two halves of the servo canister can be separated and reassembled in the correct orientation........a word of warning here separating the two halves of the servo canister can be dangerous as there is a bloody great spring in there!
I’m away & I’m working on a comparatively small phone & am not seeing details the same as on my main computer.
Granted the S1 Freelander predates the LE500 by a lot but it could form a “halfway house” system?
An addendum.
I’ve just looked at more info on the LE & I’ve reread Cobb’s contribution & it occurs to me that it’s not just orientation it’s also fixing centres.
If you were to remove the original studs & replace them with rivnuts at the correct position & spacing, you could make a spacer to accommodate the rivnut collar to ensure the air tightness of the system.
If someone will throw me the parts I’d have a go at making a system.
Just a thought.
