Heater and switch mod
The wiring was a headache but I got there and am very happy with the results so far. I had to adapt the window switches as the passenger one would not work with the TF wiring, so I simply added a one shot adaption to match the driver side and the wiring was reduced enough to work. Please excuse the heater switches as I'm still waiting for my stainless steel potentiometer switches from Italy. I've just attached these cooker ones whilst waiting.
I’ve changed all to blue LED too which looks cool in the dark.
I’ll post some images of a hard top too that I bought damaged cheap and modded up.
I had to cut away the switch housing and leave a edge to plastic weld the stainless steel panels to.
- Away
Appreciate some will hate this mod and want to stay original… each to their own..
I’ll start. The mesh on the side vents we’re looking tatty so ordered some heavier stainless stuff , cut it to shape refitted it with hot glue & trimmed it with chromed strip. When I fitted the 160 air box with the dual air intakes I broke one of the ram pipe bells. I ordered a couple of aluminium offerings & grafted them on.
Anyone else?
Here’s a hard top I bought for 30 quid that was split and I repaired with glass fibre resin. I respirated with a roll of masking tape to make a union flag that was blended out. Cheap as chips and looks good too.
- Away
The other comment with regards to the ram pipe; if you look on eBay under Velocity Stack you will be faced with any number of themes & variations. I bought the cheapest I could find because that’s just the person I am. Cheapskating as way of life. The less I spend on one thing the more I have to squander on something else.
When I joined the T-bar almost every post was someone modifying, upgrading or otherwise fiddling with their cars & that was my parish, which is why I felt at home.
Over the years & with the odd exception that has waned, so it’s good to see someone putting up their mods’ for all to see.
- Away
