Clutch
The gears are extremely difficult to engage and there is almost no resistance to the clutch pedal .
The clutch reservoir appears empty.
When the ignition is off I can select the gears, when the engine is started I can’t select any.
Is this a sign that the clutch has gone?
I’m going to top up the clutch reservoir to see if that makes any difference.
Should I buy any particular clutch fluid, or will a universal one do?
Thanks
Bob.
- trevtherev
- Journeyman MGer
I can start the car in gear and it gets it moving.
I assume the clutch has gone.
- sworkscooper
John
I should have mentioned that I’ve done 50,000 miles, which obviously isn’t excessive for the original clutch.
He sought my assistance in diagnosing the problem.
What I found was the problem was with the clutch hose itself, the outer hose sleeve had split but the inner hose liner was still intact, so when under pressure the outer sleeve would open up and the inner liner would balloon out through the spit in the outer with no loss of fluid.
2. The easiest access is to undo the rear clips so you can fold the back of the hood forward, unscrew the engine cover then remove the air filter assembly (assuming your car has the original air box and not a pipe to an after market performance cone type air filter). You should now be able to access the clutch slave cylinder from the top. .
3. Preferably with 1 or even 2 assistants bleed the air from the clutch slave cylinder. The slave cylinder has a bleed nipple the same as you would see on a brake caliper. Ideally use a tube from this running to a jar or container under the car to catch the fluid. Or just slide a big tray of some sort under the car if you dont have tubing that will fit. Ensure the fluid reservoir is full and check periodically during the process. Get an assistant to push down on the pedal whist you open the bleed nipple. Close it before the pedal is raised. repeat multiple times. Keep checking and topping up the fluid level as it will quickly go down during this procedure and you dont want to suck air back into the system and have to start from scratch. If you have access to a one person pressure bleed system you wont need to be at the back of the car but you will still need to pause from pushing the pedal to check the fluid level.]
4. Check the state of the clutch slave cylinder and it's flexible hose for signs of a leak. This may only be evident when the pedal is being held down. If in doubt replace the flexible hose and the clutch slave cylinder. Both can fail and if they havent been replaced for several years just do it anyway. They arent difficult or expensive to replace. As Cobber said check the flexible hose for ballooning under pressure.
