Running temperature / cooling fans
The only TFs that I've driven are my own and a couple of others that I was considering buying, so my knowledge of what they "should" be like is sketchy.
I have driven my TF 135 several small trips and two trips of 60-ish miles and I've never noticed either cooling fan cutting-in. It's been pretty warm here lately, but it's Scotland, so that's been 18-22 degrees ish. The temperature gauges behave exactly as I would hope - up to a little under half way on the coolant temperature gauge after 5 minutes or so, and it stays there solidly for the full time using the car.
Of course, I'm a hypochondriac , and paranoid about the car overheating. The fluid in the expansion tank behaves fine (not up or down when hot). I've tried disconnecting the fan temperature sensor, and the fans burst into life.
However, the engine bay does seem pretty hot to me, and the boot does get fairly warm.
So, Is this behaviour normal, or do I have a problem such as a malfunctioning sensor?
Thanks, Ryan.
Replied by Notanumber on topic Running temperature / cooling fans
Posted 1 year 5 months ago #2026522003 TF 135 sunstorm
Not me most here think I’m mad for thinking that’s comfortable tee shirt weather……must be my Scottish ancestry.
Given that the engine is a very snug fit in its bay and the fact that being hidden back there, offers bugger all air flow around it, means these things do retain shitloads of heat.
In order to help properly disperse this heat and reduce the heat stress on the engine, and any components in the engine bay that wouldn’t enjoy the heat soak, I fitted two small fans to the under side on the grill at the top of bay to push air out as the air flow is pretty poor, yes the is a fan that blows air in from outside sucking through one of the side vents but this airflow mostly just takes the path of least resistance and disperses out under the car without disturbing the hot air trapped in the upper engine bay.
I used some 12V fans from a quad bike, they look like bloody computer fans and probably that’s what they basically are, but as they are from a quad bike they should be pretty tolerant to mud, muck and water. They’ve been on there for donkey’s years and have given no trouble at all.
I wired them in with a relay that takes it trip feed from the in feed of the engine bay fan.
They pump out an amazing amount of heat!
This helps to keep the wiring insulation from baking hard, the electronic components from being cooked, reduces heat stresses on the engine itself and any plastic or rubber bits that might deteriorate over many extreme heating and cooling cycles.
I did a write up here some years ago, you might do a search of the archives.
Try here
In fact you should checkout the archives to gain the wisdom of the ages anyway…… mind you only take the wisdom on board, leave the stupidity behind.
And yes you Must fit a low coolant alarm, no ifs or buts will be tolerated, it is pure insanity to run these cars without one.
The cost of fitting one is insignificant in comparison to a cooked engine!….which is a fairly likely outcome if one isn’t fitted.
You’ll get no pity from me or anyone else with any sense around here if you don’t!
I use the Browns & Gammons low coolant alarm and can highly recommend it, but I do understand that there are alternatives, although I would avoid the nasty el cheapo type that involves screwing self tapping screws into the plastic header tank.
Remember the quality remains to be enjoyed long after the price has been forgotten.
In the meantime, as my coolant levels haven't altered, I take it that the fans haven't come on because the engine hasn't needed them, and stop worrying?!
Replied by Airportable on topic Running temperature / cooling fans
Posted 1 year 5 months ago #202660It was interesting to look back at Cobbers handy work from years ago with particular attention to his supplementary fan, I’m in the middle of sorting a similar system using four 80mm fans mounted on the boot lid. They may resonate & use the boot space as a sound box, I’ll only know the day after the parcel arrives.
- sworkscooper
Replied by sworkscooper on topic Running temperature / cooling fans
Posted 1 year 5 months ago #202665John .
1st Cooling Fan Switch ON 102c OFF 96c
2nd Cooling Fan Switch ON 117c OFF 112c
Engine Bay Fan ON 75c OFF 65c
Engine Bay Warning Light ON 130c OFF 110c
The thermostat starts to open at 86c and is fully open at 102c
Cheers, Mark
Posted 1 year 5 months ago #202673As sw’cooper commented earlier it’s been hot, the mercury in the thermometer hasn’t worked as hard as this for a while & if the doom mungers are correct it’s going to get hotter with every passing year. I reflected on those thoughts last year when I grounded out on a snowdrift in the Landy; only the second time in all the years of Land Rover ownership I’ve had to dig out.
Cobber mentioned his fitting of a supplementary cooling fan & I’m doing the same only I’m not shifting the same volume of air & I want to control it via a thermostat, these figures will become datum points for later experiments.
Thank you Mark.
- billcoleman
- Journeyman MGer
Replied by billcoleman on topic Running temperature / cooling fans
Posted 1 year 5 months ago #202693Now I am driving it around in the summer, I haven't noticed them ever switch on in normal use, but the temperature gauge is a stable normal.
The engine bay fan nearly always runs for a few minutes after driving in the town and defiantly kicks the heat out of the compartment.
When rebuilding the car, I noticed that the fan is positioned to flow air across down through the gap behind the bulkhead heatshield and over the top of it (around the exhaust manifold). So in my pinion, the fan is mainly there to stop the fuel tank getting too hot. I don't think that the engine itself is bothered by the high air temps because all engines run at high temperatures.
By the way, I have noticed that there is an Air Duct in Front Bumper (https://rimmerbros.com/ItemImages/Large/DXJ000020.JPG). My car does not have one fitted. Is this because it is missing or because it has air con?
Posted 1 year 5 months ago #202773Im adding a delay unit this time to avoid the likelihood of false alerts on hard cornering - not that i have experienced any but whilst pre built 12volt delay circuits are 2x for £ 5 on Ebay it seemed a useful enhancement.
