Bleeding clutchagain
- trevtherev
- Journeyman MGer
"..a tremendous amount of travel before the clutch bites, at the very end of the pedal" to clarify, does it bite at the top or the bottom end of the pedal travel ?
- trevtherev
- Journeyman MGer
Primarily I work on my own with the occasional visits into my enclave by an assistant & I rarely need a pedal pusher.
It makes no sense.
Having read loads of horror stories about refilling the coolant, trepidation quotients were set at red on the first attempt. Sticking strictly to our “how to’s” & after a couple of burps at each bleed point it was fine. However so entrenched was the myth of airlock that I spent the next week convinced it couldn’t be right & familiarised myself with the head gasket replaced procedures.
I’ve changed the slave cylinder about eighteen month ago & using my “Easibleed” it was done quickly & successfully.
Brakes have had the Easibleed treatment but I had to make an adapter for the master cylinder as there was no adapter supplied.
Any advice on using the Easibleed? Don’t use too high a pressure, as little as you can to get it working AND keep an eye on the fluid levels. Obviously.
It's all but at the top of the travel.
If you mean that the clutch only "bites" (i.e. revs drop and motion starts) as the pedal gets back UP to the TOP of it's travel, then I suspect that the real problem is a badly worn clutch plate, or just possibly a plate contaminated with either engine or gearbox oil (unlikely, I would have thought). If you have detected any clutch slip (typically, full throttle going up a steep hill with engine near maximum torque rpm), then you DO have a worn - out or contaminated clutch. -Sorry to be the bearer of bad news, because gearbox will have to be detached, and I understand this is quite difficult in-situ, and dropping the subframe is not exactly a trivial job!
- trevtherev
- Journeyman MGer
I would look at the slave to clutch arm there should be a small amount of play between them when the pedal is fully up, if not I would take the slave off to check the piston is going right back to fully engage the clutch. I read recently of a similar problem on a midget where someone previously had fitted the wrong slave push rod (longer) but I doubt that's the case here as you do not mention this as being changed. If you have to take the slave off I would be tempted to fit a new one anyway and work from there.
The elephant in the room is all the new bits were they all like for like? did anyone compare them? if the wrong clutch cover or release bearing was fitted it could give these symptoms as could incorrect fitting. Hopefully you will find a quick cheap fix and share it on here even if it's embarrassing, I only know a bit cos of all the mistakes I've made :slapme:
Those who didn’t make a mistake didn’t make anything.
Having digressed from the subject, my experience on tractors was that as the clutch wears it disengages with less pedal movement not more, I suspect that if it is travelling to the floor to disengage then; air in the system or wear/slack in the mechanical linkages or the a faulty clutch. A very remote possibility is that the upgraded release arm has the arm at slightly the wrong angle to the shaft. Mistakes do happen in low volume production, I have recently received an adjustable suspension arm for another car, it had right handed threads at each end instead of left hand at one end and right hand at the other.
EDIT
I have just re read your post, I thought that you meant that the clutch only disengaged close to hitting the floor, hence the grinding of gears and kangaroo petrol.
I had to chose between the tractor or the MG, I can drive a tractor any time, the MG was a glitch in my wife’s matrix & I got away with it.
My lad & I could throw a gearbox out & back into a Land Rover in no time, I was a lot younger then.
