Hood Questions:
1. Were any O.E.M. hoods produced with seams running front-to-back.?
2. Has anyone else had problems with wear in the fabric adjacent to the hinge illustrated below:
3. I seem to have a visible gap between the rearmost part of the hood frame, and the bodywork. Is there any way to reduce this?
In case the meaning of my "front-to-back" in question 1 is unclear, my "new" hood is illustrated below:
My original hood was this one:
Any information would be welcome. I have repaired the wear holes (which the seller of the hood had warned me about) with Black Stormsure. I am hoping that the patching material on the inside will reduce rubbing & wear on the inside of the hood. The liquid material applied to the outer surface took several applications and a damp mixing stick before the holes were properly sealed. The fully-set rubbery sealing material looks durable and quite ugly, but hopefully will prove durable and waterproof, which is all I need. Anyone out there with long-term experience about durability of Stormsure products?
To the best of my knowledge the glass screen came later in the Mk2’s life, let’s refer to it as a Mk3 & to have one in a Mk1 is decidedly odd.
When I refer to Mk’s I’m referring to hood Mk’s not car marks.
Others might have a different understanding, my comments are based on empirical observations.
At least the lateral seamed hoods had glass windows fitted & so I’m devoid of any other ideas, Sorry.
- ohnonottwins
- Novice MGer
It was only after letting the hood down and putting the hardtop on for winter that i realised the side frames of the new hood, when collapsed, now sit higher than those of the old hood. The outer part of the frame are now touching the hard top's rear window rubbers at both sides. I dont remember having any clearance issue with the old plastic screen type hood.
Is this normal for glass windowed hoods, dont they sit quite as neat and flat as the standard hoods when they are down ?
In our cases retaining the cake along with the ha’penny isn’t an option, maybe others jibs are better cut.
As someone has just mentioned hoods with a glass rear window. I changed my hood for one of these recently.
Yes, I have noticed that my "new" (glass widowed) hood sits higher, when lowered, than the original plastic windowed job. As someone else said "Ya don't get owt for nowt"
- bryan young
