MG TF 135 Blown up motor
I have a TF 135. The last time i did the timing belt I forgot to remove the locker of the valves gear so when I turned it on the engine explode. I am thinking about putting a new engine iin it but the 135 is quite difficult to find where I live so I was thinking about using a land rover freelander unit (1998 90.000 miles) and fiting the mounts, sensors, inlet and outlet from my current 135. Would that be posible?
Thanks a lot.
Not every number will make sense but I’d start there.
Better idea.
Download the Electronic Parts Catalogue (EPC) for reference, it’s in our library in the community section. It can be found elsewhere but I was told off by David for name checking Dieters web site. Oops I did it again.
I’m fairly certain that there’ll be an equivalent EPC for the Freelander. Cross referencing against the two would, I think, give you a head start.
I wouldn’t care about losing those 15bhp my biggest concern is if it would work at all. I can’t think any reason it shouldn’t except for electronics but swapping the sensors should solve that.
Someone knows if this has been done before?
(best use that with a 135 ECU for best results if in doubt)
You’ll also need the engine to be complete twitch all the sensors, injectors etc.
Somewhere on this forum there is a thread about what’s needed to change the engine from the MPI to the VVC.
