rise in coolant level
- RichardsMG
- Apprentice MGer
There are no stupid questions, so here's my stupid question: I noticed the coolant level in the expansion tank of my 2004 MG TF 160 VVC (± 75.000 km) has risen to about an inch above the max indicator when the engine is at (normal) operating temperature – when I open the boot lid after a ride. The level gets back to normal (max) in about 15 minutes. I'm aware of the fact it is called an expansion tank, probably for a reason, but is it for that reason? For the reason that coolant expands when hot? Or, and that's my fear, is it an early symptom of the dreaded head gasket failure and is pressure from the combustion chamber finding its way to some coolant bore? As far as I know the car has its original head gasket. It drives, sounds, behaves absolutely wonderful.
I've asked Google of course and the consensus seems to be that coolant does indeed expand when hot, but by that much? The "hot" level is about halfway max and the top of the expansion tank…
Maybe I'm just suffering from HGF anxiety…
Richard
Head gasket tester sniff tester should bring up one or two types.
- RichardsMG
- Apprentice MGer
And well, HGF isn't the end of the world, it's just the end of the world for the present head gasket
Richard
I’m glad of the myopic outlook of these ex owners, as my car improves in comfort, speed & facility with each addition. On Thursday it had a fixed steering column, today it has an adjustable one.
I now have to wire it up!
- RichardsMG
- Apprentice MGer
I first tried to reach the bolt on the cooling rail without taking the "bonnet" off. Youtube Man managed to do it that way. Not me…
I drove it to Orléans today, six hundred something kilometers, with rock steady temp needles – and lots of rain.
Richard
I had an opposite problem on my Skoda, although the coolant level was correct on cold mornings the low coolant light would come on, if I drove just a few hundred yards then stopped and restarted the engine the light would go out.
- RichardsMG
- Apprentice MGer
Concerning the Skoda, if coolant expands and shrinks just like any other liquid, maybe the drop in level just made the sensor trip?
Richard
Theres probably nothing seriously wrong but even if so, the parts for a head gasket change are less than a dinner out with the Mrs, a few hours weekend spannering and a great sense of achievement
Nigel
- RichardsMG
- Apprentice MGer
Today we did Orléans to Beynac,430 km in a horrendous downpour that lasted for hours, motorways like riverbeds, even the French slowed down, no really, except for white vans of course, and no water ingress whatsoever! Not a drop seeping from the cheater. Bone dry. Would the adapted heater air intake, the petrol lines inserted in the door rubbers, hours and hours of fiddling with window adjuster bolt and nuts finally have worked?
This thing goes up motorway climbs like stink…
Richard
