Vibrating Instrument binnacle cure
Paul makes an excellent reproduction of the binnacle from fiberglass. I've installed his reproduction binnacle on both of our Fs.
[size=10pt]Mark[/size]
95 MGF
Replied by Notanumber on topic Vibrating Instrument binnacle cure
Posted 2 months 3 weeks ago #207368In both cases I removed the binnacles, reinforced the front mounting points with small washers and deployed soft plastic U shaped panel edging around the lower edges to stop them clattering against the dash. One binnacle had a couple of cracks in but turned out fine once i had repaired with bumper filler and reinforced the underside. A coat of textured paint followed by a couple of coats of matching upholstery dye and a matte laquer sorted it convincingly though.
Replied by Airportable on topic Vibrating Instrument binnacle cure
Posted 2 months 3 weeks ago #207371It’s the absence of these which give the percussive accompaniment to your journey. I have to say it is a looong time since I did this job, so you might have to interpret what you see against my recollections, but we’ve managed to get here by applying common sense, why should that fail us now.
Unfasten the front screws & lift away the shroud, you will see the remains of the original fixtures. Dispense with the wreckage & push the screws back through the dash, these will fall into the heating duct. A magnet & a little inspiration will recover these. You can buy from your friendly eBay store U shaped rubber / plastic edging, run this around the bottom edge of the dome & reassembl.e
Posted 2 months 3 weeks ago #207372Please Log in or Create an account to join the conversation.
I used the plates because the holes allow the 2 pack to squeeze thru and make a good bond with the binnacle but cleaning and keying is also important.
Posted 2 months 3 weeks ago #207418To avoid a distracting reflection in the windscreen It would need to be in a neutral colour and not to be shiny ; a lesson learned from my first attempt, white plastic U channel edging was swiftly removed and replaced by more discrete black edging.
There is a practical advantage in having the binnacle relatively easily removable as it can make changing the dash bulbs less fiddly
Posted 2 months 3 weeks ago #207421Taking the instrument cluster out isn’t a regular process but when it’s required you want it to be straightforward, how you’re supposed to undo the connectors with the shroud in place is a mystery. Older & less prehensile hands make this hard enough as things stand, calling for a grand child to help would be the only option it those fixings remained.
This is one of the blocks that locate around the rim nearest the driver and accept the final securing screws.
They are about 6 to 8mm square roughly.
Anyone know of a source for these please? Rimmers don't appear to stock them.
Posted 2 months 3 weeks ago #207433Fitting rivnuts reenforces the framework & allows you to reassemble without the original fitting dictating the torque required to tighten; that remains firmly in your hands. The machine screw you are now using is totally under control.
Posted 2 months 3 weeks ago #207455If you do need the inserts though then Darren at Bitz has some 2nd hand ones
I’m waiting for some suitable 2 pack glue to arrive and will bond them in for now.
Rivnuts sound a good idea but you do need the tool to pull to form the clinch.
Now, how in the name of what’s his name do you part the top half of the steering wheel nacelle from the bottom?
Which half has to be squeezed to release it from the other half?
Can anyone help with that.?
It is now obvious that you need that top half removing to give enough room to withdraw the instrument panel surround away from the instruments so that it disengages from the clips at the bottom of the instrument covering clear face.
