Vibrating Instrument binnacle cure
On a lengthy journey in the last few days and whilst my wife was driving I was able to seek out the source of a rattle that is irritating to say the least. By shoving a bit of cardboard between the top of the dashboard and the half-moon instrument binnacle it was possible to reduce the rattle caused by the two plastic components rubbing against each other.
Has anyone managed to cure this in a more professional way?
I know there are plastic/rubber strips with a "P" profile that can be bought from various sources and was thinking that forcing a strip douwn between the two components around the binnacle might be a possible cure even if not ideal.
In a perfect world it might be possible to remove the half-moon plastic instrument shroud (is that easy?) and use a sealant such as "everbuild" mastic or similar before re fitting the half-moon surround or the "p" profile strip.
Has anyone got better ideas?
I wouldn't be surprised if the mountings aren't broken, as for a solution you probably need to find another...but good luck with that, they're as rare as rocking horse shit!
Paul makes an excellent reproduction of the binnacle from fiberglass. I've installed his reproduction binnacle on both of our Fs.
[size=10pt]Mark[/size]
95 MGF
In both cases I removed the binnacles, reinforced the front mounting points with small washers and deployed soft plastic U shaped panel edging around the lower edges to stop them clattering against the dash. One binnacle had a couple of cracks in but turned out fine once i had repaired with bumper filler and reinforced the underside. A coat of textured paint followed by a couple of coats of matching upholstery dye and a matte laquer sorted it convincingly though.
It’s the absence of these which give the percussive accompaniment to your journey. I have to say it is a looong time since I did this job, so you might have to interpret what you see against my recollections, but we’ve managed to get here by applying common sense, why should that fail us now.
Unfasten the front screws & lift away the shroud, you will see the remains of the original fixtures. Dispense with the wreckage & push the screws back through the dash, these will fall into the heating duct. A magnet & a little inspiration will recover these. You can buy from your friendly eBay store U shaped rubber / plastic edging, run this around the bottom edge of the dome & reassembl.e
I used the plates because the holes allow the 2 pack to squeeze thru and make a good bond with the binnacle but cleaning and keying is also important.
To avoid a distracting reflection in the windscreen It would need to be in a neutral colour and not to be shiny ; a lesson learned from my first attempt, white plastic U channel edging was swiftly removed and replaced by more discrete black edging.
There is a practical advantage in having the binnacle relatively easily removable as it can make changing the dash bulbs less fiddly
Replied by Airportable on topic Vibrating Instrument binnacle cure
Posted 1 week 8 hours ago #207421Taking the instrument cluster out isn’t a regular process but when it’s required you want it to be straightforward, how you’re supposed to undo the connectors with the shroud in place is a mystery. Older & less prehensile hands make this hard enough as things stand, calling for a grand child to help would be the only option it those fixings remained.
This is one of the blocks that locate around the rim nearest the driver and accept the final securing screws.
They are about 6 to 8mm square roughly.
Anyone know of a source for these please? Rimmers don't appear to stock them.
Posted 6 days 15 hours ago #207433Fitting rivnuts reenforces the framework & allows you to reassemble without the original fitting dictating the torque required to tighten; that remains firmly in your hands. The machine screw you are now using is totally under control.
