Quick question on headlights.
Can the headlight lens be removed from the unit?
My OSF headlight has fog on the inside. I have done my usual headlight sanding and polishing and can see it is internal.
They aren't cheap to buy!
Thanks Brian
Thanks Brian
1st there is no such thing as a quick question regarding the headlights, the damned things are questionable on every level, even at the best of times! this is a trait they share with many other modern cars..........Geez I miss the old 7" rounds and quad 5" rounds, you would swap out the factory installed rubbish for some quality from Cibie, Hella or some such in minutes! At the worst you'd have to add relays, taking a little more time.
With modern cars we have to suffer the rubbish that the bean counters decided we should have in order to sharpen their priority of the bottom line.
I've not done the TF headlights so I can't help you much with those as I have an F, and those in the F can be dismantled with great care required. but I'm sure someone will be along soon to enlighten you as to the peculiarities of TF headlight surgery.
Last Edit:1 month 1 week ago
Last edit: 1 month 1 week ago by Cobber.
- judiths handyman
- Journeyman MGer
Replied by judiths handyman on topic Quick question on headlights.
Posted 1 month 1 week ago #208835
I did not have the problem described until I fitted the rear rubber cover that was missing, I can only assume the rear cover is holding the moist air in, as removal of said cover cured the issue over a week or so.
Not the solution I know, but the headlamps are in a fairly well protected area anyway without need for the covers, in my opinion.
And yes, they are bloomin expensive.
Thanks for that!
It does look like condensation to a point and I was hoping my DA polisher would warm the glass enough to disperse it.
I'm about to go and remove the rubber covers and give it a try.
Edit: covers removed and fingers crossed.
Last edit: 1 month 1 week ago by TA22GT. Reason: additional information.
- judiths handyman
- Journeyman MGer
Posted 1 month 1 week ago #208838
I did also clean the lamp glasses externally, I used very fine wet and dry paper, 1200 or some such and a proprietary 3M lens cleaning kit. It worked very well all in all.
I think I may refit the dust caps but punch a hole somewhere to allow airflow.
In my spare time I sometimes refinish guitars for friends and so I have grades from 80 -5000 and I usually start with about 1000 and work up to 3000.
After that my DA will polish it to a mirror shine.
I did think about putting holes in the rubber but I will wait to see if removing them cures the problem.
Thanks for your help.
It isn't hard to remove the clear "lens" from the black headlight moulding, you just put it into an oven with the temperature set at 135C for seven minutes. Then using those plastic trim removal tools gently work your way around levering the lens off. You will find that you will have to reheat the headlight again before it eventually come off. To refit the lens you will need some butyl tape which you cut to length and fit into the black headlight moulding, another seven minute in the oven and press the clear lens into the butyl strip. It's not too bad after you have d0ne the first ne..
4PCS CAR TRIM REMOVAL TOOL KIT SET PANEL DOOR PLASTIC PRY DASH INTERIOR CLIP
by MGB281
Last edit: 1 month 1 week ago by MGB281.
