Adding Spotlights to MGTF - wiring help needed pretty please!
Replied by Malakite on topic Adding Spotlights to MGTF - wiring help needed pretty please!
Posted 1 year 8 months ago #209172
Hi Cobber.  They are the actual standard MGTF Front Spotlights that fit at the bottom of the front bumper.
I did manage to find the following diagram online which I presume I can use as the correct guide to place the wires into the back of the green connector to place into the spotlight switch?  The question would then be what wires from the main loom I piggyback them into?  Also where the two separate wires connect to also that are coming from my kit loom? I will take a pic of the main loom in the car to see if that would help you to (hopefully!) help me work out which wires are which :-)
Last Edit:1 year 8 months ago by Malakite
Posted 1 year 8 months ago #209173
Hopefully you can see the last two pics - they are viewing as attachments for me and not in the message body...not too sure why thats happened?!
Replied by Cobber on topic Adding Spotlights to MGTF - wiring help needed pretty please!
Posted 1 year 8 months ago #209175
yeah there is a trick to getting you attached pix to show properly, I think you have enough on your plate for now, with out that adding to the confusion.
We’ll worry about that later. You need to find some where handy to ground the earth wire to the body, there will be a screw that you can use. Doesn’t matter which one, so long as it makes a good groun. As for a power feed you can either go for an always live which means you can take it from any plain brown wire that has some useful diameter or if you only want it live when the ignition is on you probably need to go from one of the circuits at the fuse box that turn on from the ignition switch
by the way I need to be pedantic here, if your lights are the standard MG fare, they are not spot lights, they are fog lights.
the difference being fog lights have a short low cut broad beam pattern which is to sneak under the fog without reflecting back at you  and dazzling you they are also not meant to to dazzle on coming drivers, whereas spot/ driving lights a
have a long range “spot” beam.that reaches beyond your head lights for extra range, these will dazzle on coming traffic if you don’t dip them and if you try to use them in fog the light will reflect straight back at you, so you will be dazzled. This is an important distinction when wiring these up as with spotlights you need to wire then so your dip switch turns them off with your main beams,
with fog lights they can be wired a couple of ways traditionally they really should be wired so as when they are switched on the headlights are off but a lot of cars these days allow both headlights and fog lights to run at the same time, so as the foglights can provide broader illumination around town this is useful for keeping an eye out for idiot joggers, nuisance cyclists, wayward pedestrians, silly dogs, and rampant kids etc.
Replied by TA22GT on topic Adding Spotlights to MGTF - wiring help needed pretty please!
Posted 1 year 8 months ago #209176
Hiya..I have a TF with those lights under the bumper. They are opaque and are Fog lights, not spotlights.
As such, legally they should only be able to be used on dipped beam.
As Cobber says, if you only want them to work when you flick the switch then what Cobber has just posted is all you need. If you want them to be in tandem with dipped beam and go off when you switch to high beam, to be legal, then they need to get the switched live from the dipped beam Live.
I have not had my car long and I have no idea where it is in the loom. This is what Cobber is trying to find out for you.
BUT..I have seen so many cars take the switched live from the back of the dipped beam headlight. They piggy back a connector to the live at the dipped beam bulb and that goes to the live on your switch. Then you can only have the fog lamps on when you are on dipped beam because the live to your switch is cut when you go to full beam.
Spotlights are different. You want the switch to bring them on any time you turn them on and with main beam you light up the road!
I believe yours are Fog lights.
As Cobber says, it's a very easy job for any auto electrician.
Good luck.
Posted 1 year 8 months ago #209177
Hi there Cobber, or should I say 'G'day' (me old Cobber!)?! ;-)
OK so are you referring to the earth wire that is under the hood (blue in colour)?
I will go take a pic of the front fog/spots now and post up!
Posted 1 year 8 months ago #209179
A solid blue wire probably shouldn't be grounded.
Here are the British standard for wiring colours, note there can be variations due to idiots who worked on the car may have used whatever they had laying about.
Posted 1 year 8 months ago #209180
Hi guys - here is a picture of the front fogs/spots.... they were always an optional extra on these cars were they not!
Posted 1 year 8 months ago #209181
Yes those are foglights.
It's about the only extra my car came with!
I could have been more help on this one had I not been resolving some extramural incident. I’ll have a look later & try to take some of the heavy lifting off Cobb’s, who, incidentally, has done a sterling job.
One question, are the tf switches pin compatible with the f, the green plug looks identical but that’s not always the case.
From what I can make out from the diagrams; all wiring should be in place, including the one behind the switch. To commission the system you would need to fit & terminate the lamps, insert the appropriate relay into the vacant space in the passenger fuse box , insert the terminal into the switch. With the headlights & rear fog guard lamps on your spots should work.
I cant help feeling that you have been bamboozled buy the seller & you have further bamboozled yourself in the fitting. Now could be the time to step back & reassess what you have, what need & to approach from a different direction.
Those who know about & understand these things would have it rattled off in next to no time, but if these things don't form part of your discipline you could end up making the very rod that you are now laying across your own back. Don't kick yourself around about it, you did the best thing & that was to ask.
Posted 1 year 8 months ago #209477
hehe Brilliant!
Posted 1 year 8 months ago #209478
Hi and sorry I have taken a few days to reply - sadly I have been laid up in bed and so not managed to achieve anything at all! My plan is to crack on with it all towards the end of this week! Re: your question - I am not too sure about TF and F switches.. all of mine are the same and the one that came with the pack seems to be the same too....
Time to create page: 0.504 seconds
