Replacing expansion tank
Replied by sean79 on topic Replacing expansion tank
Posted 1 year 8 months ago #209506
Thank you, much appreciated
by sean79
Replied by Cobber on topic Replacing expansion tank
Posted 1 year 8 months ago #209507
Since you are going to this trouble, you are of course fitting a low coolant alarm if not already fitted, and if fitted are fitting a tank suitable with the low coolant alarm.
NO iif's or buts.....or sooking about cost! A low coolant alarm is essential for our cars, It is utter madness to try and run our cars without on fitted, the cost is nothing compared the the cost of not having one! you have been told........stay told!
There are several available, one of our members offers one that is highly regarded, I myself have run the excellent Browns & Gammons Low coolant alarm for over 10 yrs without any trouble.
Failure to head this advice WILL result in a dismissive I told you so! Do not set yourself up to be a victim!
Replied by Delbourt on topic Replacing expansion tank
Posted 1 year 8 months ago #209509
Why do you need to get under the car to bleed the system?
The 6mm bleed on the water rail is accessible after removing the engine bay cover.
The rad and heater bleed points are from the front bonnet.
If you are not disturbing the hose on the engine other than at the tank why do you need to get underneath?
Posted 1 year 8 months ago #209511
Are you confusing the bleed points with the drain plug?  The bleed points are all accessible from above, as I said check the procedure in the how tos, or the workshop manual also downloadable from this site in the libary section
Replied by Notanumber on topic Replacing expansion tank
Posted 1 year 8 months ago #209526
Most definietly fit a low coolant alarm if you have not already got one. BuceTF135 on here does a very inexpensive and foolproof one which fits to the existing expansion vessel, that several of us have. Other types are available
Replied by BruceTF135 on topic Replacing expansion tank
Posted 1 year 8 months ago #209529
I have recently discovered a small crack in the expansion tank...... I have bought a new one but is it possible to change it without having to bleed the system if I clamp the pipes soon as I take them off?
Thanks
As said previously, you don't need to drain down the system to change the expansion vessel, as it is the highest part in the cooling system.
  • Start by draining, sucking, or syphoning the coolant out of the vessel.
  • Undo the two screws that hold the tank in position.
  • You can then lift it even higher before removing the two pipes and keeping them held up.
  • Fit the new tank and reconnect the pipes.
  • Replace the coolant.
  • It would be sensible to bleed the 3 points referred to above.
As also mentioned previously, I can do you a better than eBay deal on a low coolant alarm.  Just send me a private message.
Posted 1 year 8 months ago #209578
Yeah sorry, was totally confusing it and wording wring due to alcohol consumption 🤣🤣
by sean79
Posted 1 year 8 months ago #209579
Thank you
by sean79
Posted 1 year 8 months ago #209580
I wouldn't exactly say it's utter madness to drive one without it, when everything that can be done has been done (without low level sensor) and she gets driven about 15 miles 6 days a week and a good run out on the 7th day, after I've let her warm up for 20 minutes or so..... If ain't broke, don't fix
by sean79
Posted 1 year 8 months ago #209587
No of course you're right..........until you're wrong, and you will be!
Just fit a low coolant alarm, or suffer the consequences of you're tight arsed false economy.
I'm looking forward to saying "I told you so"
This is a case of
if it ain't broke it soon bloody well will be!
And don't give me the bullshit "Originality" line..... keeping it totally original will be keeping all the totally original problems.
Replied by Laurence J on topic Replacing expansion tank
Posted 1 year 8 months ago #209597
Bruce135 low coolant alarm is inexpensive, easy to fit, and on these cars it’s a no brainer!
Replied by TA22GT on topic Replacing expansion tank
Posted 1 year 8 months ago #209598
Just fitted one today. Superb piece of kit.
Laurence the Piper Cone filter is fine. 50 -60  in traffic you don't notice it at all on light throttle...at 70 in 5th it's not moisy at all. When you give it full throttle through the gears it sings but it puts a smile on my face!
The following user(s) said Thank You: BruceTF135, Laurence J
Time to create page: 0.558 seconds
