Locked driver’s door
Replied by Uncle Nick on topic Locked driver’s door
Posted 1 year 6 months ago #210216
That is a real bummer.
I was sure a good clean and lubrication was all it needed.
It sounds like a solenoid from what you describe with the clicking but I'm guessing.
I hope you find a s/h one that has been tested.
Good luck.
Thank you.
I’m also blaming the solenoid and guessing it works but doesn’t have the oomph any more to pull hard enough. Happens to us all at some point I guess! 🙄
Posted 1 year 6 months ago #210217
Ahh! The”machine gun” melody of the rattling lock.
What a complete pain. I bought a second hand lock, cleaned it externally, washed it out with switch cleaner and re greased it in readiness for fitting. Roll forward a few months and it was fitted (and I know what you mean by being difficult to fit - I had the thing in and out a few times becoming proficient at it . I’d say 10 minutes max).
Anyway replacement fitted it locks/unlocks on the door button, locks/unlocks on the fob button. With some trepidation I tried the super lock. Not sure if it is good or bad but that part didn’t work. So until I remove it again to disable that aspect I live in fear of pressing the lock button too many times.
Good luck with getting it out again.
On re fitting it might be worth “fooling” the system by “closing the latch” with a screw driver rather than fully closing the door.
Thank you.
Wow, 10 minutes is impressive, it takes me far longer than that to assemble to tools and go out into the cold!
Closing the latch while the door is open is a great idea, wish I’d thought of that before I closed the door.
I’m now thinking that whichever way I open the door, and what/whichever lock I fit, I’ll simply leave the plugs undone and remove the solenoid issues from the equation.
Replied by Delbourt on topic Locked driver’s door
Posted 1 year 6 months ago #210218
When I say 10 minutes I mean with the door card off etc not just from a cold start with everything assembled and the door shut!
Replied by Goodwood on topic Locked driver’s door
Posted 1 year 6 months ago #210225
The locks tend to give a bit a warning before they go. They make a sort of 'whirring' sound prior to the 'machine gun'. Basically the inner plastic mechanism eventually fails and is not repairable. Once you start to hear any sounds, it is best to lock only using the key (on my car the superlock and lock occur at the same time, that is how it was programmed) and plan on replacement ASAP. This is what happened to me earlier this year. Of course, as others have said, it is best to make sure the lock is lubricated regularly to help ensure longevity. Replacement is fairly straightforward as long as you can open the door!
Replied by D4KGP on topic Locked driver’s door
Posted 1 year 6 months ago #210227
I find petroleum jelly works as good as anything on these parts.
Posted 1 year 6 months ago #210228
Does anyone know what the actual difference is to locks of left hand and right hand drive cars?
I’d assume the connections for the rod to the key turn but anything else?
Driver side for RHD seem to be in very short supply.
Is it not possible to replace just the solenoid? I’m going to have to investigate mine further once it’s out again.
Replied by Airportable on topic Locked driver’s door
Posted 1 year 6 months ago #210229
The system is a motor & gear train. It is dependant on the train to be synchronised for the mechanism to operate correctly (self evident) & like most inquisitive members who have these problems, I’ve taken one to pieces.
I’m only aware of one successful & long lasting repair, it wasn’t mine.
A while back a member who is no longer active stated & I paraphrase, “I’ve taken my lock to pieces & no matter how hard I’ve tried I can’t do a proper repair. I’ve done this so you don’t need to waste your time, buy a replacement “.
I would underscore this sentiment!
The following user(s) said Thank You: TA22GT, Uncle Nick
Replied by David Aiketgate on topic Locked driver’s door
Posted 1 year 6 months ago #210231
Door lock Repair    👈 CLICK CLICK
Many moons ago, Clive dismantled and repaired a door lock. His how to is very instructive...
Last Edit:1 year 6 months ago by David Aiketgate
Last edit: 1 year 6 months ago by David Aiketgate.
Replied by Cobber on topic Locked driver’s door
Posted 1 year 6 months ago #210232
L/H locks would be a mirror image of a R/H lock so whatever is asymmetrical about one will be opposite on the other. I wouldn't mind fitting a L/H lock to my car.
It's just temping fate............One day, I can see the battery being flat and the drivers door lock choosing that moment to shit itself, of course I'll need to get in desperately and wont be able to because the imbiciles only put a lock on one side!
Of course one I have locks on both sides, providing me with an easy solution, then fate just won't bother and this problem will never occur, as I'd taken all the fun out of it!
I could be wrong but I do seem to recall something about some of the low spec  (poverty pack) 1.6 litre cars  had locks on both sides as they didn't have central locking.
Posted 1 year 6 months ago #210233
Door lock Repair
Don’t suppose you know where that how to is?  I looked but can’t find it.
Replied by TA22GT on topic Locked driver’s door
Posted 1 year 6 months ago #210234
Click on the highlighted blue link in David's post.
It looks like a good read.
The following user(s) said Thank You: Uncle Nick
Posted 1 year 6 months ago #210235
In my quest to find a replacement lock, I’ve seen an advert for a non central locking actuator for the very early cars, at  an astronomical price.
It appears that soon we’ll only be able to get LHD locks in the UK and will have to drill the extra key hole.
Time to create page: 0.488 seconds
