mg tf 160 bad head gasket
Something else to consider is where did the pieces of piston material go to? 🤔What additional damage, if any, has been caused?
It's got the number "135" stamped in the side. Could this be a piston from a 135 engine?(or are they the same and it doesn't matter?
I wonder if some ham fisted ape hasn't broken the piston installing it, and pulled the lose bit out before bolting down the head and hoping for the best.
What does the bore of the liner look like?
Short pistons..no wonder they like to rev.
I wonder if someone broke a ring whilst replacing them at some time.
Personally I would have left the liners in place unless scoured.
You are far enough on to do a great job of rebuilding it now and the satisfaction you will get is enormous. Well done.
I will leeave it at that.😉
I agree totally, DON'T attempt to weld up the piston!Do not even remotely try to weld up that piston!
In any case, they have 160 stamped into them on the piston top face.
Edit:- Scrub that, I think I can see 160 on your piston...
