lubricating clutch release arm
- bluesunshine
- Apprentice MGer
the clutch pedal on my mg tf is quite stiff so i think its time to apply some lubricant to the clutch release arm . Whats the best way to gain access to the arm ? Through the engine inspection cover or underneath the car ?
many thanks
Whenever I’m in the engine compartment il give it a squeg although you may be fortunate in having an oil nipple on the end. These are after market parts * & certainly worth fitting if you have cause to have the gearbox out.
* did some of the later tf’s have these, I don’t recall?
- bluesunshine
- Apprentice MGer
Replied by David Aiketgate on topic lubricating clutch release arm
Posted 1 year 6 months ago #210598Basically some oil soaked fabric in convoluted plastic trunking.
Life!
Thanks David.
- batoutofhull
- Novice MGer
Buy a small hand pump spray, add liquid and spray from the top of the engine bay.
I did this after my clutch was slipping. It works its way in then turns into a grease. No faff.
Two years later still working.
from the website.Slipstream Flow Gel 2 is a highly penetrating lubricant, originally designed for conveyor chains (metal, nylon, polyethylene, polypropylene, ABS etc), and for Bowden cables. It has since found wider uses in hinges, gears and bearings that are difficult to reach with normal grease applicators.Flow Gel 2 is formulated with a mixture of solvents that evaporate at a controlled rate to leave behind one of our best selling greases.Flow Gel 2 is formulated from FDA approved ingredients and has USDA H1 approval for lubricants with incidental food contact. It is hardwearing and versatile and extends chain and cable life by penetrating right into pins, linkages and braided steel wire. It may be applied by brushing, spraying or pouring. After the solvent has evaporated, Flow Gel 2 becomes a long-lasting, non-drip, lubricating and weatherproofing gel.
They also do IFC gel. very similar.
I've found oil spray used for bike chains works in a similar fashion.
Actually lubricating conveyor systems can be a huge problem, if the lude is too light it won't do much good but if it's too thick and sticky all the shit sticks to it and works it's way into the bearings and drive chains, wearing them out. I've spent a great amount of my working life fixing this shit and still haven't come up with a great solution. Neither has anyone else!ToadKeeper post=211029 userid=26232Having miles of roller conveyor belts hammering along 25 / 7, that required lubricant that stayed in place, I suspect he found better alternatives.
Most just pump in ever more lube, but that only creates more problems with all the excess lube picking up yet more filth and risking contaminating the product as well as over heating the bearings.
when a breakdown stops production. Usual daftness I imagine?
Contamination is a big problem. A water leak led to, something like, 10 Tonnes of chocky being thrown away. What the ***** you do with 10 Tonnes of chocolate I have no idea.
Probably got some happy pigs locally.
