lubricating clutch release arm
Replied by bluesunshine on topic lubricating clutch release arm
Posted 1 year 6 months ago #210574
Thanks for your reply , much appreciated
Replied by TA22GT on topic lubricating clutch release arm
Posted 1 year 6 months ago #210589
I read every post on here and devour the information...so guess what I will be doing next time I have the engine cover off...
Replied by David Aiketgate on topic lubricating clutch release arm
Posted 1 year 6 months ago #210598
Long long ago in a galaxy far far away, a clever chap devised a clutch arm lubrication system.
Basically some oil soaked fabric in convoluted plastic trunking.
Replied by Airportable on topic lubricating clutch release arm
Posted 1 year 6 months ago #210603
Clever & easily instituted, I’ll think about that, that is until I forget.
Life!
Thanks David.
Replied by batoutofhull on topic lubricating clutch release arm
Posted 1 year 5 months ago #210932
There is a product called slipstream. It is used in food manufacture to lubricate conveyor belts and rollers. It is an evaporating liquid that evaporates leaving a grease the consistency of smooth peanut butter. It is not the same colour though.
Buy a small hand pump spray, add liquid and spray from the top of the engine bay.
I did this after my clutch was slipping. It works its way in then turns into a grease. No faff.
Two years later still working.
from the website.Slipstream Flow Gel 2 is a highly penetrating lubricant, originally designed for conveyor chains (metal, nylon, polyethylene, polypropylene, ABS etc), and for Bowden cables. It has since found wider uses in hinges, gears and bearings that are difficult to reach with normal grease applicators.Flow Gel 2 is formulated with a mixture of solvents that evaporate at a controlled rate to leave behind one of our best selling greases.Flow Gel 2 is formulated from FDA approved ingredients and has USDA H1 approval for lubricants with incidental food contact. It is hardwearing and versatile and extends chain and cable life by penetrating right into pins, linkages and braided steel wire. It may be applied by brushing, spraying or pouring. After the solvent has evaporated, Flow Gel 2 becomes a long-lasting, non-drip, lubricating and weatherproofing gel.
They also do IFC gel. very similar.
The following user(s) said Thank You: Airportable, Pharg55, generous_dad, TA22GT
Replied by VinceR on topic lubricating clutch release arm
Posted 1 year 5 months ago #210973
As it happens I have a son in law who is a Production Engineer for Mars.  I'll have a word!
I've found oil spray used for bike chains works in a similar fashion.
Last Edit:1 year 5 months ago by VinceR
Last edit: 1 year 5 months ago by VinceR.
Replied by D4KGP on topic lubricating clutch release arm
Posted 1 year 5 months ago #210990
Yeah, chocolate and toffee I find it lubricates well. LOL.
Posted 1 year 5 months ago #211029
Having miles of roller conveyor belts hammering along 25 / 7, that required lubricant that stayed in place, I suspect he found  better alternatives.
by VinceR
Replied by Cobber on topic lubricating clutch release arm
Posted 1 year 5 months ago #211037
ToadKeeper post=211029 userid=26232Having miles of roller conveyor belts hammering along 25 / 7, that required lubricant that stayed in place, I suspect he found  better alternatives.
Actually lubricating conveyor systems can be a huge problem, if the lude is too light it won't do much good but if it's too thick and sticky all the shit sticks to it and works it's way into the bearings and drive chains, wearing them out. I've spent a great amount of my working life fixing this shit and still haven't come up with a great solution. Neither has anyone else!
Most just pump in ever more lube, but that only creates more problems with all the excess lube picking up yet more filth and risking contaminating the product as well as over heating the bearings.
Last Edit:1 year 5 months ago by Cobber
Last edit: 1 year 5 months ago by Cobber.
Posted 1 year 5 months ago #211050
Especially when "The Management" whine about every attempt at preventive maintenance?    Then get in maximum flap
when a breakdown stops production.  Usual daftness I imagine?
Contamination is a big problem.  A water leak led to, something like, 10 Tonnes of chocky being thrown away.  What the *****  you do with 10 Tonnes of chocolate I have no idea.
Probably got some happy pigs locally.
Posted 1 year 5 months ago #211054
I deal with that sort of shit every day, one confectionery manufacturer I worked for had absolutely no idea, they had a conveyor carrying going through a small port hole in a wall, I was asked to enlarge to hole, I inquired when there would be a break in production so I could cover the conveyor to do the work, I was told there would be no halt to production as they were behind, and couldn't afford to loose any production and I would need to do it while the line was running! So I did what they asked and of course shit fell onto the conveyor and all the product which of course all had to be thrown out!
So how did throwing out all that product help their precious production numbers?
They got me to design a machine to sort licorice logs for chocolate coating, when it came time to build it I needed some Stainless stell flat bar, they wouldn't buy any and told me I had to see what I could find in the bone yard, the only usable stuff I could find was on what appeared to be a new ice cream cone forming machine., I told them that that was all I could find and they insisted if it was there it was rubbish and I should cut it up and use it, so I did. I built their sorting machine and left soon after.I  heard the owner got upset when he couldn't find his new icecream cone former! He was convinced someone stole it, and the morons in middle management weren't going to own up that they told me to cut it up. What a bloody circus!
I can hear you ask why would I do it......malicious compliance, you know what is going to happen and you warn them of the consequences, but when the refuse to listen because they are all knowing, you just do it ,cover your arse and let the smartarses deal with the fallout of their own stupidity!
That mob ended up going broke....surprising isn't it?
Posted 1 year 5 months ago #211079
Way back in the mists of History I was a Programmer Analyst on IBM machines.
I was asked to write a prog. suite to analyse company salaries - INCLUDING the top management.
I had to promise never to look at any of the data whilst writing the thing.
Cross finger time!  I'm lead to believe it was most interesting, obviously I have no idea.
by VinceR
Time to create page: 0.451 seconds
