Engine Bay Fan Check
Engine Bay Fan Check was created by billcoleman
Posted 1 week 4 days ago #210137
Hello
Last year I fitted a new engine bay fan because the old one looked like it was about to fall apart with corrosion.
After that, it was very common to notice the fan cut in and out when driving around town - Summer or Winter.
But now, I never hear the fan start.
Can I check its functionality using PSCAN?
Replied by D4KGP on topic Engine Bay Fan Check
Posted 1 week 4 days ago #210138
Surely you can check it by disconnecting it from the sensor situated above and forward of the expansion tank, when disconnected it should run.
Replied by Airportable on topic Engine Bay Fan Check
Posted 1 week 4 days ago #210139
That depends on which car Bill has; Mk1 f definitely, I’m unsure of Mk2 but not Pektron tfs.
Replied by David Aiketgate on topic Engine Bay Fan Check
Posted 1 week 4 days ago #210141
David Aiketgate replied:-
The mk2 F still has the temp sensor north of the expansion tank. I believe the first TFs, with the square lucas fob, also retained that sensor.
Last Edit:1 week 4 days ago by David Aiketgate
Last edit: 1 week 4 days ago by David Aiketgate.
Replied by pscan.uk on topic Engine Bay Fan Check
Posted 1 week 21 hours ago #210207
which ECU is this?
Replied by EllisoJo on topic Engine Bay Fan Check
Posted 1 week 4 hours ago #210224
I can confirm that Early, Lucas FOB TFs also have this switch where you show it, and it does cause the engine-bay fan to come on once disconnected.  At least, it does on my 2002 TF.
Time to create page: 0.546 seconds
