Guides coming soon...
Replied by cjj on topic Brakes
Posted 16 years 5 months ago #10287
Rough Luck;10283 wrote: Cheers for the pics I really didnt expect them to be so accurate
is it only the holes on the discs that have been drilled (which way) or do they look standard??
Not too sure what you mean mate. The discs are drilled to fit the pcd of the F.
Rough Luck;10283 wrote: I take it from your drawing on the block one step is 17.5 and the other side is 21, so are they right and left handed??
Yes they are right handed and left handed.
Replied by rough luck on topic Brakes
Posted 16 years 5 months ago #10291
the wheel stud holes have been drilled as you said
can you tell if the holes have been extended toward the centre of the disc or away from the centre, sort of total length of the wheel stud slots on the disc
cheers
Replied by Adam-Mgtf on topic Brakes
Posted 16 years 5 months ago #10320
still following this, looking forward to the results guys :)
Posted 16 years 5 months ago #10328
Was going to fit them today, but it was lack of sleep that was the killer. Had 3 phone calls, one from a .org member, still, they're not to know that I'm sleeping. Didn't get up until about 4.30.
Replied by David Aiketgate on topic Brakes
Posted 16 years 5 months ago #10333
CJJ;10328 wrote: Was going to fit them today, but it was lack of sleep that was the killer. Had 3 phone calls, one from a .org member, still, they're not to know that I'm sleeping. Didn't get up until about 4.30.
Excuses, excuses........................................ :tomatoes:
Posted 16 years 5 months ago #10337
On the plus side, I now have a set of stainless steel nipples to replace my old knarled ones. :yesnod:
Posted 16 years 5 months ago #10347
CJJ;10337 wrote: On the plus side, I now have a set of stainless steel nipples to replace my old knarled ones. :yesnod:
Ooh, new nipples! and stainless too! Wow :whistle: ....
Replied by a Guest on topic Brakes
Posted 16 years 5 months ago #10370
I've got my one-off solid set today :) Looks like good quality for the money to me. The disks aren't super but they are easily exchanged for i.e. EBC solids if they wear hard or corrode too much. I'm happy :)
Posted 16 years 5 months ago #10371
OK, guys,
we all know that the centre bore of the discs is 56.6mm. Right?
And the rings that Clive has received take the bore of the Focus discs down from 63.6mm to the 56.6mm. Right?
Well I still have my old rear discs laying about in the yard and when I measure them, the centre bore hole is 66mm.:dunno:
When I look up new discs online the centre bore is stated as 66mm.:dunno:
Could somebody explain this please, as me am confuddled?
Posted 16 years 5 months ago #10377
Managed to fit the offside disc today. It all went quite easily, so here are some pics.
These are some before shots.
And with the wheel removed.
With the old disc removed you can see the difference between the new 280mm and the old standard 240mm.
and you can see the difference in offset between the discs. The new disc is shallower so sits further into the wheel.
With the old disc removed, and the hub cleaned up, the first thing to do is fit the spigot ring. This holds the disc central and stops wheel imbalance at high speed. The spigot ring needs to be fitted with the recess facing the hub.
The next picture shows how the carrier extension block bolts to the hub. They are handed and the stepped part should face you with the narrow end of the step at the top. We do not fit this yet as we need to bolt it to the carrier.
Fit the disc onto the hub, using the retainin screws, bolt the extension block to the caliper and bolt into place. The supplied screws are shorter and allan headed, but are very soft. I will be cutting my stainles ones to size and using them.
And with the wheel fitted you can see the difference. Even if it doesn't give better braking I am glad I did it just for the better looks.
I will fit the nearside one tomorrow and have a good drive to bed the pads in and then get it back on the brake tester to see if there is much difference.
My next job is to fit these to the front:
and these all round
Posted 16 years 5 months ago #10378
If I put the before and after you can see the difference.
Posted 16 years 5 months ago #10383
Looking good Clive.:yesnod:
Does my previous query regarding centre bore mean that the standard discs are only positioned by the studs and not on the centre Bore?:dunno:
Time to create page: 0.435 seconds
