Guides coming soon...
Replied by cjj on topic Brakes
Posted 16 years 4 months ago #10609
Adam-MGTF;10606 wrote: i may be wrong but i read on the Type R forums that EBC greenstuffs are only rated to 200bhp?
I have never seen brake pads rated to bhp before.
Braking forces would more be a product of weight of the vehicle and speed, so a 5 ton vehicle with 100bhp would take a lot more stopping power than a 1 ton vehicle with 300bhp, both slowing from 70mph.
Replied by a Guest on topic Brakes
Posted 16 years 4 months ago #10626
Just mounted mine. I feel the calipers (which are floating) are being pulled-in by the handbrake cables because of the new caliper position. Don't have time to investigate it right now. Did you readjust the cable mounting points CJJ ? Are your wheels turing freely ?
Posted 16 years 4 months ago #10629
No problems with mine mate. The cable end mounting points move with the caliper.
Posted 16 years 4 months ago #10664
I know they move with the caliper but the entire inner + outer handbrake cable is pulling on the caliper. The mounting point for the cables is in the engine bay just behind the inlet manifold. I don't know if this mounting points leave some room for "sliding" the cable a few cm towards the caliper. I will update on this issue later.
Posted 16 years 4 months ago #10691
These are the fixing points at the rear of the engine bay.
I don't suggest you remove the engine and subfram just to get at them. :)
I can't remember whether the cable slides through them or whether they are fixed.
Posted 16 years 4 months ago #10737
Thanks for the picture that will help me allot ! I'm goin to wait until the snow has gone befor I slide under the car ;)
Posted 16 years 4 months ago #10965
Just checked and the brakes were definitely rubbing because of tension on the handbrake cable. Fixed it by removing 1 of the bolts of the clamp and rotating the cable to a better angle. It's not possible to slide the cable in the clamp. It seems fine now.
Still need to cover some distance in order to get the full benefit from the disks. Right now it's slightly pulling to the left because the left disk is quicker bedding in than the right because I'm using my old pads. I'm sure this will be solved in a few 100 km's.
Replied by David Aiketgate on topic Brakes
Posted 16 years 4 months ago #11202
Clive,
have you been back to get your brakes tested with the all new setup on?
I am very interested in knowing the final outcome of your upgrades.:yesnod:
And promise not to dispute the findings, 'onest .:whistle:
Posted 16 years 4 months ago #11210
Will probably be next weekend now.
Posted 16 years 4 months ago #11212
CJJ;11210 wrote: Will probably be next weekend now.
Oaky doaky!:)
Posted 16 years 4 months ago #11656
Still interested, Clive. Any update?:dunno:
Time to create page: 0.470 seconds
