Mission impossible
I have replaced almost all of the wiring including the fuse box in the car. Earlier on you mentioned the seat belt pretetioners would need to be changed..I haven't done this on the driver side yet 🤔 also I didn't change the yellow wiring cables for the srs as it all looked good but I have changed the srs module.
I mentioned that the steering lock was stuck on....unfortunately that wasn't a fault with the locking system but the whole column was seized solid! This has also been replaced.
On the SRS front. You say you’ve fitted a replacement column, have you retained the original wheel? Have you looked at the clock spring & associate paraphernalia, both in the wheel & behind. Having just advised the judicious use of contact cleaner on the steering electronics, I would keep the SRS contacts dry plugging them in & out a number of times to let the contacts wipe themselves clean.
One thought “off the wall”, the replacement SRS unit you have could be configured for dual airbags, if that’s the case your light isn’t going to go out.
And if, when you’ve changed the remaining seatbelt fireworks you’ve still bogged down change the yellow loom, then make friends with someone with a Pscan.
Here are a couple of photos of the original unit.
Looks like someone sneezed in there!
I'm just about to have a look at the srs side of things, hopefully with better results.
I'm going to take a break from the electrical gremlins tomorrow and rebuild the break calipers ...I'm actually looking forward to this as I don't have to upside down. 🙂
Tying in with your comments on the twitching of the speedo, there are inputs from both engine speed & road speed, there is also a mysterious reed switch shown on the monochrome diagram. I need to look at that as I've no idea where that could be other than within a sensor, if that were the case why not illustrate it as such.
You mention having a look at the brakes, there's an excellent parts supplier in Burnley who carries all the rubbers & also the needle roller bearing for the handbrake mech'.
Needles to say I continue to follow with interest.
If the weather holds and nothing else goes wrong then tomorrow I will fit a new master cylinder ( taking no chances after the clutch problem) and bleed them.
Nothing fancy, just standard calipers but I have fitted a servo brace and stainless hoses.
A little sad? Maybe but others find pass times entertaining which leave me a little perplexed.
I wish that the designers of our cars had been been that organised then I wouldn't spend half of my time going back and forth trying to find the correct spanners..
This means I too find myself wandering from workshop to garage to collect a spanner I put away a few minutes ago.
That too is a bit sad, however I know that you will empathise, whether Cobber will is a moot point.
