Engine Cover (Yes again)
i would need to know the magnet diameter and protrusion from the mounting face.
Hence I made my own.
And again we see the value of our site; one member introduces us all to new products or ideas & everyone has the opportunity to benefit.
Thank you Daedalus for another great idea.
There is about 10mm plus of room at the bottom to allow for bigger speakers, however the gap under there is for the sound deadening. I have fitted silent coat on mine, so it wouldn't be an issue, but it may be for some others.
There is no room to move the speakers forward as the grill is very close to the front of the boxes. I think the best thing would be to add a hump or similar to clear larger magnets.
I'm off this week, but when i get back next week, I will print a set off
Fascinating, and easy to, cock up if you don't know what you are doing I imagine.
You can buy (or make) a drill press type attachment for a soldering iron to press them in, but there are no square edges on these to make it worthwhile.
I dont have the diameter of the magnet but remember thinking at the time that it looked almost as wide as the front of the speaker in the centre.
- generous_dad
What 3D printer would I need to do what you did and what software are you using?
As I can just about get that worst bolt to start I don’t think I’d commission a T bar. But if time passes and I struggle more to get that bolt to start I think I’d come up with a large enough hole for the head to pass through and come up with some fiendishly clever washer arrangement.
you might think of 3d printing that stepped washer set.
Make the central 3 hood latches removable as well and it is ALMOST fun.
