280mm brakes (again)
Replied by Cobber on topic 280mm brakes (again)
Posted 3 weeks 2 days ago #223997
Surely a standard 16" wheel should fit over those discs, or am I on the wrong track here?
By standard 16" wheel, do you mean a steelie? Finding a steel 16" wheel in the stud pattern would be an interesting challenge!
Or do you mean a normal alloy MGF/TF 16" wheel? I dunno if a 16" would fit in the spare wheel well, I know that a lot of the 16" equipped MGF/TFs had a tin of squirty tyre gunk in place of the spare wheel. I've gotta set of 16"s laying about the place, awaiting the big brake conversion , that I've also got lurking in the shed, I should see if one would fit in the hole.
Last Edit:3 weeks 2 days ago by Cobber
Last edit: 3 weeks 2 days ago by Cobber.
Replied by Daedalus on topic 280mm brakes (again)
Posted 3 weeks 2 days ago #223998
I like steel wheels, if available, i would have steels instead of alloys. I have found a company that would make me some 15 x 6J steels, but i would have to buy 1500, which is probably more than i would need.
Posted 3 weeks 2 days ago #223999
Just think of all the spares you'd have!
It's probably easier to paint your wheels another colour to disguise them a bit if you don't care for the alloy look!
Mind you back in the old days it wasn't unheard of to cut away the narrow steel rim from the centre and the weld on a wider rim or they'd cut the rim in half and weld in a rolled flat bar into the rim to widen it. Skills such as these have long gone now!
Replied by Notanumber on topic 280mm brakes (again)
Posted 3 weeks 2 days ago #224000
I was surprised my 135 had a 16" alloy spare when i got it.. Id assumed all those with 16" road wheels came with a tin of gloop - apart from those who carry a 14" spare and just accept they will have to do a 3 way swaperoo if they get a puncture on the front. All the 16"s spares are full sized alloys, just painted black to differentiate them which seems excessive but was just because it was easier than having a small run of 16" steel rims made up in our PCD just to offer an optional spare.
I like the idea of banded steel wheels and have been keeping my eyes open for a set for my daily driver. My MGB project car nearly got them but that has now ended up with some 16" Enkei alloys that were on my donor car with stud adaptors.
Posted 3 weeks 2 days ago #224001
I can buy the hoops easy enough, its just the centre, because of the tiny PCD, i suppose i could try gettins some spun and them lasered, it would just be the pressing tool then for the bolt holes
Replied by Delbourt on topic 280mm brakes (again)
Posted 3 weeks 2 days ago #224003
To answer a couple of questions.
Yes the standard MGTF 16” wheels will undoubtedly fit over these 280mm discs. I have standard 15” wheels with the 6 spoke pattern and they fit. I know that some of the earlier 15” wheels do not but I don’t know which ones.
Secondly I have loaded a standard 16” wheel from a TF160 into the boot well and been able to close the bonnet. (I selected a random wheel with a tyre from some spares I have). I suspect the tyre is one from a front wheel rather than the wider one from the rear. To find out I’d need to lift it out and confirm the size but sadly Im not about to do that.
Replied by D4KGP on topic 280mm brakes (again)
Posted 3 weeks 2 days ago #224004
On my TF there is a standard 16" aluminium 16 spoke spare. But on the other TF that is waiting for me to spend more time on it, there is the gunk set.
I wasn't aware that you were all talking about 15" wheels, so I apologise for interjecting.  G.
Last Edit:3 weeks 2 days ago by D4KGP
Last edit: 3 weeks 2 days ago by D4KGP. Reason: Just an update on my earlier comments.
Replied by David Aiketgate on topic 280mm brakes (again)
Posted 3 weeks 1 day ago #224013
I can confirm that a 16" wheel fitted with a 215/40 16 tyre will fit perfectly in the spare wheel well.👍👍👍 No problemo!
There is a minor inconvenience that some cars fitted with the standard 14" spare had a shorter threaded bolt on the hold down that won't engage the nut when using a full size spare. Cars with 16" spares as standard have a longer threaded bolt.
Last Edit:3 weeks 1 day ago by David Aiketgate
Last edit: 3 weeks 1 day ago by David Aiketgate. Reason: More info
Time to create page: 0.396 seconds
