MG T-Bar Quiz
- a Guest
- Visitor
As PQ said TF as well :whistle:
- cjmillsnun
They're a hydragas thing.. They're a shortened knuckle that connects the hydragas to the suspension arm.
They effectively lower the suspension to the trophy settings..
So...
From http://www.mgfcar.de/data/IMS_Trophy.pdf
Front trim height 348mm ± 10mm
Rear trim height 343mm ± 10mm
With TFs the suspension heights are controlled by the springs. So to lower a TF you would get a set of different springs like these http://www.mikesatur.com/acatalog/Online_Catalogue_Suspension_Steering_31.html
- a Guest
- Visitor
Mike Satur also states; To improve both the looks and handling of the car we recommend our lowering knuckle pins. Lowers the standard ride height by 30mm. (Standard ride height 368 +/-10mm)
There are several lowering options for the TF. The two provided by Mike Satur are the Blue kit lowers the car by 12mm and the Red kit lowers the car by 25mm.
- a Guest
- Visitor
- a Guest
- Visitor
- Mr Forgetful
Anyway, I'll go back to just watching the Quiz as the questions are far too complicated for know nothings like me. :nonod:
What did Jean Cook say F'ers should do?
Edit: Ted you are correct, taking the question as written word for word. I took into account the SS dimension and assumed the question was about lowering both the F and TF by their respective methods.
- a Guest
- Visitor
jump into it and drive it to the Isle of Skye on the roughest roads to find out what it is really like
Edit yes PQ I worded it wrong sorry Mr F :oops:
