Remote boot release.
I'm so glad you got my subtle hint, Yeah, I'm as about as subtle as a 3rd ball on a greyhound!Thank you Judith's personal mechanic....a very precise reply.
I have the square fob but I would need to send it off to be programmed so I thought to get the key done at the same time. I also admire your discipline but it is mindfulness I suffer from...lol.
Cobber! No I don't have a P Scan yet but I took your very subtle and delicate hint that I should get one! I am sure I will as I go along but right now more exciting things need to be done like better brakes.
It does appeal to me though to fit a boot release for when that day comes. Fitting it outside the car means I don't have to break a window to activate it when the car is locked.
I think you just growl and leave the biting to others!! lol
As suggested above I like the idea of having it outside the car and near the number plate lights. The kit comes with a solenoid and the push button switch. I could mount the switch between the number plate lights and cover it with a domed rubber grommet. It would be hard to tell it was a switch.
Like this one:
just a simple on/off switch, they're used in industrial applications all the time. the trick is not to have it on the same key ring.
Perhaps keep a copy of the key in your wallet.
Then again just keep a copy of your boot key in your wallet.
I was thinking if I took an incoming live to the boot lock and ran it through the new momentary switch and out to the other side of the lock it would do the same thing as the key. Yet you could still use the key..until I lock it in the boot...
I haven't got the TF in my head yet and the car is locked up so I am just working it out in my head..there's not a lot in there to help me!
The eddies that are created as you travel & the turbulence there in, will draw grot into your switches, either from the front or if mounted through the plastic work, the back. One salty winter & that will be it, even a good quality switch would suffer & there are precious few of those now. You’ll be so pissed off when it doesn’t work, that in your ill humour you’ll end up locking your keys in the boot.
QED
My “interesting ideas” are born out of life on the edge of the unhinged. In the past I’ve been asked to design items for inclusion in classic cars to provide more up-to-date facilities & my long suffering car acted as a test bed. As such it is tasteful littered with all manor of trinkets waiting to cause me grief. However it’s a great way to keep what’s left of the cerebellum in working order.
- BruceTF135
It all seems fairly simple apart from actually mounting the actuator onto the boot lock. This looks like it will be best done by a contortionist!
I want it on the outside so no matter where my keys are I can get in if needed!
I found a 12v 16amp push button switch, supposedly waterproof and a 16mm hole which is small enough to go between the lights and I will fit a rubber gromet over it.
If you get it done first send pics!!
These type of switches do resist corrosion but the weak link is the wires and terminal that connect them, though I doubt that will be all that much of a concern in your case.
I'm hoping to get it done next week. Hopefully, maybe, definitely a maybe.
