Fuel tank removal
So that explains why the pump is buggered then...... it gets worse my Jag has the same problem.......bloody petrol station must be supplying shit dirty fuel! Tight Bastards too miserable to do any maintenance! And of course the Jag has two tanks!
There is that much crap in there, that I have to remove the tank to clean it properly.
So I start to remove it, out with the t-bar, soft top, seats, seat belts, centre console, air filter box, remove fuel filler, rear carpet, rear bulkhead insulation, rear bulkhead panel.... now according the the workshop manual all I have to do is remove the tank..........well the damned thing is bigger than the hole it is supposed to come out of!
I seem to remember reading somewhere, the sad and sorry tale of some poor sod that had to do this, but do you reckon I can find it? Nah of course I can't, did a search no luck there, trolled through the how tos, nah not there either.
I thought there was a how to somewhere, but apparently not!
Had I had known we didn't have one I might've bothered recording the process in pix, a vid would be almost impossible to do due to the lack of room.
So I'm up to the point of trying to extract the fuel tank but cant see what's holding it. And have called end of play for the day. Much swearing and cursing was issued, and a blood sacrifice was made.
Maybe the tank has expanded with age, I know this happens to Fords with plastic tanks, The
series Falcons came with a 80 litre tank when they were new in @1980, but they all hold about 85 litres now!So I was hoping I could find where whoever had done it, had actually got the bloody thing out.
I can see it needs to be rolled out bottom first as that's going to be the only way the get the filler and pump mounting out but the bloody thing gets wedged in and jams at the flange round the centre tunnel. I was hoping not to need to apply shitloads of senseless violence, ATM I see little other choice as finesse has failed. If I had 5mm I'd shit it in.
These cars certainly do have character!
Does your car know who it's talking to??
Good luck Cobber it won't beat you
I read up on polymer expansion and left it to dry /air for a week. Not a hint of change.
Ended up 'modifying' (spark free) the lower lip near the floor pan.
Well done Cobber, consider it good cardio vascular exercise along with a little neuro stimulation.
I've found elsewhere that yes they do indeed expand and apparently they will contract again once the fuel is removed, but.....and here's the good bit....It can take up to 8 weeks!
If ever I meet the bloody moron that made the decision to use a plastic fuel tank in these things......I'll go all medieval on his sorry arse, no torture will be too inhumane for this dipshit!
As for that prick that owns the bloody petrol station he better stay outta my way too, especially as I have both tanks in the Jag to do, I already know how much of a bastard they are to do, I haven't looked at the TR7 yet and that too is a bastard to get the tank in and out of!
NOT HAPPY!
Airportable post=209086 userid=5200I’m flying by the seat of my pants (Jockettes)on this one. But if you bung up the holes, bar one & apply an industrial vacuum to that, you might reduce its volume by that tad you need for it to pop out.
Nah I think you'd need a bit more of a vaccum than you'd be able to generate with a domestic or even comercial vaccum cleaner, if I were to go that way, I suspect I'd be more likely to get results by enlisting physics to help if I could fill it with hot water, seal it, and somehow shock cool it.......it will collapse, but how to do that without crushing it to the shithouse is the question ? Too risky really. And the problem outer dimensions probably wouldn't contract, it would just suck the sides in.
The problem is really one of chemical reaction, I suspect a subtle blend of time, psychology and extreme violence will win out!
Back when we had the illegal drinking establishment we modified the steam generator of a coffee machine to clean out the beer pipes, worked a treat, we always had the best beer!
Firstly & most importantly the fuel has to be neutralised, irrespective of the methodology, unless, that is, unless you want to suck petrol vapour up adjacent to a sparking motor.
Half an hour, probably less, would have a blanking plate screwed over the pump hole & an adapter taking the filler pipe inlet to the hose on an energetic vacuum cleaner or vacuum pump.
A glamorous assistant to help & let the magic begin.
It not all that mad cap & after all we’ve covered some far out ideas on here, some as far out as the Kuiper Belt.
Maybe something like the pipe freeze sprays?
So here are a couple of thoughts. But please note I have not seen any MGF or TF tank or looked at drawings.
First, if you can see the rust is it not possible to clean the tank in situ one way or another?
Second if not and you wish to shrink the tank could you blow hot air in (down a hose from something like a hair dryer) and then “close” all openings and let it cool - but watch it cool to make sure it does not shrink too much.
it will probably cool quickly.
Worth a thought?
Steaming the crap outta the guts of it then maybe purging it with an inert gas like CO2 or N2 , might do it, but all this experimenting is starting to sound expensive, would it be easier to just cut the bastard up and replace it, but off course that would depend on a replacements availability, probably not all that thick on the ground here in OZ, second hand units are most likely next to non existent due to the fact that no bastard can get 'em out, and new ones are probably hideously expensive to to the cost of shipping something of that bulky.
Some years ago the company I worked for had a demolition job at a functioning tobacco factory, It was a fixed price quote, and amongst the problems we had was to demolish a large concrete bund.... this bastard of a thing was made in a way that I'd never encountered the reinforcing wasn't by steel bar, no it was a random network of fine strand wires a bit like fiberglass pumped through a chopper gun! This stuff was tough sledge hammers hardly made any impact and jack hammers were way to slow and labourious. to make matters worse this bund was located on an upper floor!
What I did was get in an excavator, (what you Poms call a digger) But this came with a whole new set of problems, 1st was one of access, I craned it into the upper floor, with a bloody great crane, then the client quite understandably didn't want diesel exhaust gasses in their still working factory, so I got as much flexible exhaust pipe as I could muster,and attached this to the diesel's exhaust but it still wasn't long enough to reach outside the building so it was in turn attached to some PVC drainage pipe to get the sufficient reach to get the pestulant gasses outside. this Heath Robinsonesque set up actually worked with me dragging the hose and pipe combination around as the excavator worked.
Well this got us outta trouble, but here is the relevant bit, it was amazing how much the PVC pipe expanded with the exhaust heat it swelled up to a much larger diameter It wasn't to hot to handle with my hands so there was sufficient length of flexible exhaust to allow it to cool with out melting the PVC, but still it swelled to buggery!
Anyway back to the original problem.........I got me some thinking and research to do!
I wanted some mad science thinking to do when I cooked up the K series V8 thread........and now providence has provided some..... the moral of this story is be careful of what you wish for!
And right now, currently my wishes involve thousands of tiny demons with red hot pitchforks tormenting the gentleman's sausage, wedding vegetables and fundamental orifice of both the bastard at the petrol station and the dribbling idiot who came up with the plan to use a plastic fuel tank!
