Checking radiator cooling fan
  • AU02TF
  • Apprentice MGer
  • Apprentice MGer
Checking radiator cooling fan was created by AU02TF
Posted 1 year 7 months ago #210109
My 2002 TF 135 started overheating while driving in stop-start city traffic yesterday, a warm 27deg here in Adelaide. This hasn't been an issue previously.
Temp gauge got to just above the ¾ mark but returned to normal range once we were in clear air and moving. Temp also went high again climbing windy hills roads but dropped quickly on more level terrain.
No coolant loss and inspection of the dip stick and filler cap shows nice clear oil, no mayo.
I'm suspecting the radiator cooling fan may not be working? Checked the fuse and all OK there. The engine bay fan ran for a while after stopping with engine off.
Is there a simple way of checking if the radiator fan is functioning correctly? Help please.
Possibly just coincidental, but a couple of weeks ago the expansion tank cap 'blew' with the associated spectacle of heaps of steam and about 1 litre of coolant loss. A new (genuine) cap appears to have solved that issue.
by AU02TF
Replied by Cobber on topic Checking radiator cooling fan
Posted 1 year 7 months ago #210110
The fact that the engine bay fan runs means the temp sender is doing something useful.
Why not unplug the fan and apply power and earth directly to it? It should run, if not it's buggered, and if it does run, well you need to see if it's getting turned on by the ECU.
which would involve getting it up to temp, and seeing if there is any power getting to it.
Last Edit:1 year 7 months ago by Cobber
The following user(s) said Thank You: AU02TF
Replied by Roverlike on topic Checking radiator cooling fan
Posted 1 year 7 months ago #210111
If you unplug temperature sensor on the engine which sends info to the ECU radiator fan should start working. If not either fan is not working or engine ECU is not sending signal.
Replied by David Aiketgate on topic Checking radiator cooling fan
Posted 1 year 7 months ago #210114
To test the fan's operation directly, on cars with the lucasfob (square) without AC.
Remove the yellow relay under the bonnet and use a suitable wire shunt to bridge these two points. With the ignition on, the fan should run!
Last Edit:1 year 7 months ago by David Aiketgate
Last edit: 1 year 7 months ago by David Aiketgate. Reason: Clarification
The following user(s) said Thank You: AU02TF, TA22GT
Replied by Airportable on topic Checking radiator cooling fan
Posted 1 year 7 months ago #210115
Does that apply to both f & tf David? It’s such a long time since I had the tf I can’t remember now.
Information like this is useful to store in a dusty drawer of my brain, instead of relying on someone else’s dusty drawer.
Thanks.
Posted 1 year 7 months ago #210119
It does apply to MG F and mk1 MG TF (Lucas type fob) but only in case you do not have aircon fitted. It does not apply to mk2 MG TF (Pektron fob type).
The following user(s) said Thank You: David Aiketgate, Airportable, TA22GT
  • AU02TF
  • Apprentice MGer
  • Apprentice MGer
Replied by AU02TF on topic Checking radiator cooling fan
Posted 1 year 7 months ago #210120
Thanks Roverlike, I was searching high & low for the yellow relay.........mine has AC!
by AU02TF
Posted 1 year 7 months ago #210121
All Oz spec cars have AC, which is why I made the suggestions I did.
Posted 1 year 7 months ago #210122
David Aiketgate replied:-
Thanks Damir,
I will amend my post to reflect that...
  • AU02TF
  • Apprentice MGer
  • Apprentice MGer
Posted 1 year 6 months ago #210220
OK. Thanks for the guidance, process of elimination indicates the ECM isn't activating the fan which otherwise does run.
I think I heard somewhere that there are exchange services offered by some firms - is this correct and if so, where to go? Anywhere here in Oz (Cobber?)
It's a Mk1 TF with square fob, Lucas.
by AU02TF
Posted 1 year 6 months ago #210221
Not in Oz that I'm aware of.
I wouldn't think it too difficult for an electronics geek to fix.
On my Triumph TR7 it had a little box of tricks made by Pektron, what it did was control the pop up headlights with a delay timer so the lights would momentarily stay up so as the lights could be flashed. It had shat itself so I got a geek mate to crack it open and he replaced all the crap soldered to the circuit board but the chip.....Sorted!
I ended up not using it anyway as I ended up discreetly fitting the car with both fog and driving lights, under the front bumper, it made more sense to use the driving lights for flashing purposes (saves the pop up mechanism for unnecessary ware and tear)
Replied by Notanumber on topic Checking radiator cooling fan
Posted 1 year 6 months ago #210230
If in doubt you could always create your own fan control circuit using one of theses and a simple relay. in line temp switch
Time to create page: 0.471 seconds
