Dead battery following alarm/electrical oddities
Replied by Notanumber on topic Dead battery following alarm/electrical oddities
Posted 5 days 8 hours ago #208999Well done for uncovering the boot hinge wiring problems. Unless you have already been to buy the cable I would suggest you order a metre of automotive wire in each required colour rather than general wire from a general DIY store. Wire made for automotive use is a bit more flexible which is quite important for the hinge area which is subject to vibration and movement. The insulation layer is thinner but more durable than ordinary knock about wire. It's also best to match the existing colours. Joint are best soldered and covered with heat shrink tubing
Replied by Airportable on topic Dead battery following alarm/electrical oddities
Posted 5 days 8 hours ago #209000“You keep asking & the blokes on here, for sadly it is blokes, will endeavour to help”.
Is that better Cobb’s? Maybe we might encourage the ladies (blokeses) to rejoin.
We try to be inclusive.
Replied by Cobber on topic Dead battery following alarm/electrical oddities
Posted 5 days 7 hours ago #209002"Keep calm, relax, focus on the problem & PULL THE BLOODY TRIGGER"
Posted 5 days 7 hours ago #209003To satisfy those grammarians amongst us, we would need to ascertain the mean age of the hypothetical female contributor, (spanner jockey/ jockette/jockess)
Once verified we would have to consult the good bergers of the OED to adjudicate.
Replied by TA22GT on topic Dead battery following alarm/electrical oddities
Posted 5 days 6 hours ago #209004just asking...
Posted 5 days 6 hours ago #209006"Keep calm, relax, focus on the problem & PULL THE BLOODY TRIGGER"
Replied by sludge on topic Dead battery following alarm/electrical oddities
Posted 5 days 6 hours ago #209007You are doing very well, dont knock yourself at all. You have asked, you listened, you have looked how to apply that knowledge and you have learned. That's how all of us on built up knowledge and confidence.
On my way to B&Q I thought about whether or not I should get automotive wire specifically. With needing to be mobile in the car this weekend if I can, I opted to get something cheap for now to give me a temporary fix (and to confirm that the broken loom is the cause), and then the specific automotive wire I've ordered should be here for me to replace it all during the week next week.
Posted 4 days 22 hours ago #209012It’s interesting that shat is in my spell check library, I don’t remember a text where I found myself referring to a French cat.
My most humble apologies.
Posted 4 days 22 hours ago #209013Please Log in or Create an account to join the conversation.
Posted 4 days 20 hours ago #2090142003 TF 135 sunstorm
Posted 4 days 20 hours ago #209015However if you have a good & accommodating car dismantlers I your area, I’ve found them happy for you to cut the “blood vessels” out of dead cars.
Go for non CANBUS vehicles & look for the front to back loom plus the ventricles around its electronic heart.
I’m still working out of a £5-00 bag harvested years ago.
Replied by David Aiketgate on topic Dead battery following alarm/electrical oddities
Posted 4 days 20 hours ago #209016On the battery charger front, they have become too intelligent for their own good!🤣 A really depleted battery is beyond their little brains...
I have a deliberately "dumb" charger, no electronics just good old fashioned electrical grunt.
The trick of putting a decent battery in parallel usually tricks the "intelligence" to stop being a numpty!😋
