Mission impossible
The other calculation you might consider; if you have arranged your finances in an advantageous way, the longer you live & providing you have not been profligate the more you have available to squander later in life, unless you want to leave your nest egg for your beneficiary’s to squander.
Just a thought from someone who had the great good fortune to chuck in formal payed employment a long time ago.
My plans are to get the TF on the road in the next week or two, it's only minor work left to be done. Then I have a MGB GT bodyshell that I want to sandblast and prime before the end of September ready for any repairs that are needed over winter. I bought one of those pressure pot sandblasters and thrown away everything but the pressure pot, I am hoping the You Tube videos give a true picture of how well these can work if modified.
It runs and ive moved it around the drive under it's own steam but i got it to that point over 5 years ago. Last year I rebuilt the saggy seats with new foams and webbing and have repaired the front edge of the bonnet with new metal, thankfully this is the only rust damaged panel, The worst thing about that car now is the paint as it was repainted very badly as a short term measure following an otherwise good restoration job by the PO which ate up all their budget, pre their accident. The only answer to a car covered by microblisters is to rub almost the whole car down to bare metal. A daunting task that ive still not properly started on.
The last job was to replace the upper arm bearings and I didn't want to spend more ££ on tools so I made my own.
A filed down washer some 8mm all thread, 4 nuts, 1 large washer and a bit of tube from an old gazebo frame did the job 😀
The 1st 2 came out OK but I got bored so I just put the washer in and whacked the others out. 😇
I have seen a kit on ebay that would allow me to have that option but is it a good idea?
Mike Satur sells an oval washer that slips in through the bearing then it rests against the bearing at the other end, you then insert an old pivot shaft and whack it with a hammer. It took less than five minute to remove four bearings.I'm just about ready to start putting the front end together :woohoo:
It’s whereabouts now is a mystery but I seem to remember “I’m doing the job tomorrow so I’ll get it back on Monday”. This was a Saturday & I was told he was a good bloke. Good at excuses & not answering his phone, good at running a red light when he saw me coming.
Bastard Barry thanks a bunch, at least it wasn’t the big welder. I know your not Bastard Barry the scheming turd, he’s in prison & my bush whacker is most probably in his mates unit.
You’re starting to sound like me!
If you isolate one sphere from its mate this advantage is lost & you end up with independent suspension using gas springs, you would however be able to set the system up with exact ride heights & this might give the competition car an advantage. Taking this to its logical conclusion, if you had schrader valves welded to your spheres, you could adjust the ride height at each corner & dispense with the pipework all together, with the net reduction in weight.
If you have tip top units & a pump, you can play with the system until your hearts content, choosing, at the end of the day which you prefer.
Did you get your spheres tested?
Indivualising them something that I may try in the future.
I have just had a look at the Mike Satur kit and I wish that I'd bought that instead of the one I got.
I can't see the new bearings lasting as long as the old ones did.
There’s a similar roller bearing in the rear brake mech’ associated with the handbrake, I knew they would need modifying so thought I’d try with some eBay bits, one had fallen victim to a size 9, you could see the print on half of the Jiffy bag & the second fell victim to being picked up & inspected. I got a refund kept the rubbish & put the job in abeyance.
It would be good to hear your experiences with the MGB GT. My 1979 B GT has been languishing for years after a reasonably good start replacing the front crossmember and steering gear from the PO's accident.
