Mission impossible
There is a place in Telford that can test the spheres for me I think.
I got lucky today 😌
The subframe is out and I only snapped 1 bolt. :woohoo:
Why would I have green subframe mounts? Even the rubber has green paint it.:dry:
I have had a slight change of plan.
Originally I had intended drop both subframes at the same time but I just don't have enough space to store everything and I totally underestimated just how much work it was going to take.
To anyone considering a full front end rebuild...FInd someone who will sandblast the frame ..it will save you so much time and you will get a far better result. (I didn't) :bang: I will be sending the rear though.
So everything is now clean, de-rusted, treated and ready for paint. The hubs are having new bearings and joints. The top arm's will be getting the same treatment as will the wishbones and calipers.
Everything that's going back on is going to be new or refurbished. (Lots and lots of new bolts 🔩)
I'm hoping to get the spheres tested later this week so fingers crossed 🤞
I was a bit sceptical but it's cheap so I gave it a go.
I'm very pleased with the results so far 😀
The Mrs won't let me put the subframe in the bath tho. :lol:
I also found it makes a really nice job of stainless nuts & bolts etc. whether it take the first few ferric atoms off the surface, leaving more of the chrome behind I don’t know, especially when you consider stainless vessels are used to hold really strong acids so a little bit of phosphoric shouldn’t have any impact.
Thanks.
