Mission impossible
I have several including the “Axiom of Stupidity” & bar, one of the highest accolades you can be awarded for a fundamentally dumb error.
* no gender stereotyping on the T-Bar !
A couple of questions for you guys.
Is it ok to move my car on the bump stops? (I want to move her into my garage.)
The steering lock won't release, any tips?
Failing that try your local “dial a scrote” they’ll turn up & have it undone in a moment.
As far as moving the car, very gently does it.
I only had 1 of these on the front end. "I'm guessing that the other had abandoned ship at some point"
Should I try to make a similar spacer or are they not necessary?
Obvious if it’s a control arm!
I’m sure when sufficient rust becomes available the part will disappear into a small pile of reddish brown flakes
I actually made four similar to that , two for front and rear to support the ABS cables. I found that the awful plastic clips that fit on the rubber brake hose didn't fit very well onto the smaller braided hoses.. I drilled and tapped M8 holes into the subframe and the rubber moulding on the cable fits onto it.Obsolete part?
