Mission impossible
As the one who caused the disruption I also see the benefits of informing others how things change. David is correct in saying how things were, I have tried to show how it has changed for the better. If you take his last example about the cheese maker then it's a good example of that change. He correctly states that years ago a lot of cheese whey was discharged into rivers, then they realised that by making butter from the residual fat in the whey they covered the whole cost of the cheese making process. The next improvement came with the body builders and their demand for whey protein which made the ultra filtration of whey profitable and led to new markets in the food industry in general. The only part left of the original whey is now the lactose (sugar), again this finds it's way into the biscuit makers and some goes back to the farms as a source of sugar for the cows, it actually creates a better balance of Amino Acids than molasses. It shows how a major pollutant has disappeared. It's just one example of how things change. In my lifetime I have seen other waste products become valuable ie citrus peel from the fruit juice manufactures (animal feed), the waste from making glucose syrup (antibiotic production, and a very special protein for chickens, it makes their yolks a very good colour) and the potato waste from (wall paper paste and animal feed)
I have certainly learned a lot over the last couple of weeks and the front end is slowly coming together.
So far this week I have given the steering rack a bit of a service..cleaned, re-greased, new ends and a fresh coat of paint.( Anyone have a part number or know what the foam seals are called ) see photo.
Tomorrow I'm getting the new bearings into the hubs and picking up the new subframe mounts.
Before I start putting things back into the car what is the best anti rust treatment for inside the subframe and what should I use on the new wishbones to prolong their life?
Seal - Steering Shaft Cover.
I was looking in the wrong place.
For the box sections the recommendations would be Dinitrol or Lanoguard.
Both companies make a range of products so it's the type for spraying into cavities and box sections you would need for this. If you have an air compressor there are cheap air guns on Ebay for injecting the stuff.. For the external surfaces of the lower sills and the box sections a clean down to remove surface muck and spray over with Gravitex should be good and hardwearing. Gravitex is often sold with an airgun as a package and it's reasonably priced.
Blessed are the cheesemakers.
Yesterday I was supposed to get the wheel bearings pressed in at a garage but work overran and it just didn't happen.
So after a rather large scotch I ordered a bearing press kit from Amazon..here's how it went.
There weren't any instructions with the kit so I just winged it
I really thought that I was going to pull the bench from the wall or break the bar and when there was a loud crack I was fearing the worst... However.
Needed a little clean up but you could still see the honing marks.
New circlip in and again I setup what I hoped would work and it was a good result.
When it came to pressing the flange in I didn't want to damage the inner race so I went for this setup.
Now I just need to do that 3 more times ...:slapme:
The Lanoguard looks very interesting.
