Mission impossible
Away
We have finished the interior strip down..really smelly!
I will be changing the srs module and probably the fuse board but luckily I haven't found corrosion on any of the connections yet.
I think we found why the clutch pedal went to the floor...the slave cylinder is toast and I have ordered a new seal kit for that.
I'm going to get the starter motor and alternator off for testing and or refurbishment/ replacing over the next few days.
The list of jobs is growing by the hour..:slapme:
I think the clutch problem is worse than I thought.
The slave cylinder was bad but I think it had gone past its limits.
The release arm is free but it just feels wrong..it's really easy to move and has no resistance at all. (20-25mm)
Has anyone come across this before?
Away
There won't be a single regular visitor that isn't rooting for you on this job.
I was going to drop the engine/subframe out as part of the rebuild so doing a clutch would be good practice anyway.
Would it be a good idea to try to start the engine before that so I have a better understanding of what's needed?
The euc and alarm modules. were above water and I haven't found any corrosion on any electrical connection so far.
Away
If it's coming out anyway do the jobs & then turn the key, besides won't you have water in the sump & would you want to change that & the filter before you start the jobs.
Away
Unbelievably there isn't any water in the sump however after putting a scope down there is a brown sludge on top of the pistons.:oops
Time to get the spanners out.
Away
There’s dampness in there & it might do further damage. Under similar circumstances I might be wondering how to get silica gel into a container that would slip down a plug hole, changing it every few days whilst your on with other things. It might be a pain but it just might prevent rust forming, farting about now might prevent farting about with cylinder hones further down the line, with all the attendant fuss that that would entail.
