WHEEL NUTS
Irwin tools took over Record & a number of other UK tool manufacturer & china has become the source of some items in the range; what’s fresh?
These work well & a set of Chinese branded items will cost you a tenner, there again you want the situation to improve, so I would search out the Irwin items.
No immediate solution comes to mind but the Irwin grips mentioned in #2 must be a good bet.
If the wheel is scrap that might open up other possibilities although as said nothing obvious.
Away
It’s quite a while since I replaced a stud in this way & the memory fades.
So best of luck & hope my memory of this job is off an MG & not any other car I’ve had dealings with.
give it a good whack with a 4lb (2 kg) hammer
and they should then undo easy
I have used Allen headed stainless screws with a dob of copper grease on all I work on but do run an M6 tap down the hub hole to clear out all the rubbish.
You will most probably do this as a matter of course but I included it as an aid memoir for those who might be new to greasy hands. Copper grease on the cleaned up mating surface between hub & disc.
