How long to wait - coolant bleed
I appreciate the offer of help and guidance regarding blow back..
Not quite sure how I’ll attach a hose at the radiator vent point and blow back but I get the idea.
The radiator is brim full.
With the PRT stat I need that to open before anything will circulate back to the engine/expansion tank The bottom hose is below the vent so it is entirely possible that air is in the return leg but the stat needs to open as I read the diagram.
The heater is a different issue and water should vent from that point. I’m waiting for delivery of some fittings to be able to further bleed the radiator part of the system before re trying the heater vent again.
As the rad is brim full I would expect something out of the water rail vent by the cylinder head. But nothing last time. And that is why I wish to crimp the hose to push the water down the rail rather than take the route to the head tank
Simply butt it up to the rad and blow down the tube.
The rad is full but either the flow or return pipe is airlocked preventing circulation.
It really only takes 30 seconds.
Good luck.
At present there is a tube from the heater bleed to a 1Litre bottle and during the last run I did collect about 25 mm in the bottom of the bottle. So something is getting through - eventually.
PS never did find the relay under the steering wheel. That can wait for another day.
Can you post a picture of your fusebox under steering wheel?
Hence jacking the back up or perhaps pop rear on ramps?For the heater bleed valve to work I found it needed the coolant level in the reservior increased a bit. It hardly did anything at all whilst at the normal level
Replied by David Aiketgate on topic How long to wait - coolant bleed
Posted 3 months 3 weeks ago #222543David
Replied by Airportable on topic How long to wait - coolant bleed
Posted 3 months 3 weeks ago #222544M
